Panasonic Home Theater System System Logo
A
Anonymous Posted on May 15, 2014
How can I clear the error code f61 - Panasonic Home Theater System System
avsystemparts.com
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Dec 21, 2014
avsystemparts.com
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
75307
Points
197
Power supply board malfunction, replace it. check avasytemparts.com
Panasonic SA UX100 f61 code error
F61 is a secondary power supply issue causing the mechanics to jam up or the CD mechanism has jammed causing this message.
Error code F61, what must i do to clear this. Can anyone help.
https://www.techwalla.com/articles/how-to-fix-a-f61-error-on-a-panasonic-home-theater-system
Panasonic sa-vk50 power down f61
an f61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61 I think it's for helpful for you.
F61 on panasonic SA-AK220
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
3helpful
Error F61 How to reset SC-HT995W system?
I'm sorry to say, but an F61 error can not be cleared by a reset. Please see the link below for an explanation of protect mode (F61 is Panasonic's version of protect). Usually the output amp pac will need to be replaced. This will cost between $75 and $100 for the part. Feel free to post any additional questions here.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Home cinema panasonic sc-bt100 error code f61 what does it mean
I have same F61 issue, purchased a new fan fitted it today, and I have the same error code??
20helpful
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
1helpful
2helpful
Error code 61 or f61 on my noritz 6.9
61 is the fan motor, check out the fan and make sure there aren't any bugs or dust in there
11helpful
2answers
Error code F61
Please describe your f61 error code problem:
Top Panasonic Audio Players & Recorders Experts
woodzowl307
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
