Ruud UAKA037 Air Conditioner Logo
A
Anonymous Posted on May 31, 2014
Capicator on ac - Ruud UAKA037 Air Conditioner
ellwood47
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 135 Answers
  • Posted on Sep 01, 2014
ellwood47
Expert
Level 2:
Cheetah:
Answers
135
Questions
0
Helped
22464
Points
175
What about it???????
2answers
Wha causes the compressor to not run when the fan will?
the starter capicator might be bad its on the side of compressor
We have Lennox Elite Series furnace and central air. Blower would come on but air cond. did not. He replaced circuit board ECG1, I believe. I don't think he was sure if that would repair problem. Our...
Look at the inside of the cover on the furnace and it will tell you what's the code mean.
I think because was calling for Ac that's why you are having that blinking red light.
Turn furnace off on switch and turn it back on and that should clear error code .
To check your air conditioning unit that's the unit that's outside .
Check to see if contactor is pulled in .if it is and nothing is running then check the capicator. The capicator is the oval metal thing that's tuck next to the capicator with 3 wires attached to it .
If it bulky then it's bad .
That is the most common issue with these unit.
What color wires hook up to a capicator for a Ruud AC unit
For the fan, brown usually hooks to the capacitor fan terminal and orange to the common terminal. For the compressor, purple usually hooks to the capacitor herm terminal
2helpful
Power went out today and the TV is not turning on now
Most likely when the power came back on, there was a surge that damaged the power supply board in your TV. If your TV is completely dead with no blinking or standby lights, then the power supply is bad.
The power supply is the first board that the plug from the wall is going into.
You can check this by taking the back cover off and check for capicators that have gone bad. These will be capicators that look bubbly on the tops that are budging out. If you see any and know how to solder, replace these capicators with the correct voltage and Farad readings that are usually listed on the capicators themselves. Make sure to mark which side the white stripe on the side of the capacitor is as the orientation is very important.
Replacing the capicators is usually a cheap fix but if you do not want to or cannot solder the capicators or if you do not spot any bad capicators, just replace the whole power supply board. This can be done by just unscrewing it off the LCD panel, disconnecting the connections to and from the board, replacing the new board, reconnecting, and screwing back in the new board with the same screws.
I have a Duo Therm RV air conditioner probably put in when RV was made in about 1989. Started leaking through the ceiling last year down onto my floor, so I kept it off for a while. I would only try it now...
I need more information. And if you have worked on AC's before? Thes main things to check I believ is the fan motor I just wrote out a long explanation as to what to check and look for and I think it got lost. SO I believe your hearign the compressor continue to run even when the fan stops.
Eventually the compressor over heats and stops. this is when nothig runs. Here is where I believe te indoor coil has been covered with Ice-frost and when the compressor stops the ICE FROST melts and you get water on your floor.
The motor could be bad or the run capicator  I also believe your indoor coil (and most likely the outdoor one too) is plugged up or dirty. A dirty outdoor coil is the most often cause of motor over heating and or capicator failure. If you can look through the fins of the outdoor and indoor coil ALL OVER then they are clean. Any area stopped up over 20% and you need to wash them out.
Take your capicator out and have it checke by someone with a capicator checker. They will most likely have a replacement if needed. Check the "STIFFNESS" of the motor bearings. If you spin it and it turns over 2 or 3 times or more the bearings are probably ok.  If it has oil holes add about 20 to 40 drops lite machine oil to the bearings. If they are sealed... Start looking for a repairman or take care if your goin to change it yourself. Too many factors to go into here about changing a motor. And some may or maynot apply.
Hope this helps you if I need to more clear get back to me and well discuss it more. GOOD LUCK!
Top Ruud Heating & Cooling Experts
jdthefixer
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
