Danby DDR2506 Dehumidifier Logo
A
Anonymous Posted on Jun 23, 2014
E6 error why does this error appear after tank is empty
Can I leave a dehumidifier in an unheated cottage for the winter? Where will my answer appear?
you can leave it turned off emptied in the unheated cottage. but i would not reccomend letting it run or stay with water in the tank. as water expand when it freezes. and will break the tank. also . dehumidifiers do nothing in freezing condition other than waste energy. so empty the tank and store it for the winter.
and your answer will appear right here :)
The tank is empty but the full light stays on
The full light normally comes on when the tank is full. Emptying the tank and re-installing the tank should allow the system to reset. However, if the tank isn't pushed in all the way... the full switch and indicator light will be fooled into reporting a full condition. My suggestion is, first pull out the tank, look at the float and the tank full switch. Become familiar with these two items and confident that 1) the float is not stuck in the up position; 2) the tank full switch that the float is supposed to actuate will toggle (press your finger against it and let it return.) After this exercise make sure the tank is seated all the way in place. If your issue is mechanical, its easier to fix than if it's electrical, and if it is electronic... (just pray that it isn't).
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Dehumid. was working, went to empty it and now it acts like it has no power
If you mean you emptied it, and replaced the holding tank and now it doesn't work ... The holding tank probably didn't activate the safety trigger. Remove the tank and reinstall it, making sure that the tank triggers the safety switch. That should solve the problem.
Trying to use the hose rather than emptying the bucket but water continues to drip onto bucket even tho connection to hose appears snug
This may not help because I'm not sure of what you have, but most dehumids when using a hose hook to a fitting on the tank. If that's what you have, before you hook the hose you have to either punch a knockout in the center of the hookup on the tank or cut it out. Hope this helps.
I have an LG LHD65EBL dehumidifier. When I checked on it today the unit was not running and the display read "CH 01". I tried cleaning the filter, cleaning the front of the coils, and resetting the unit by...
Hi
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
The bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
10helpful
3answers
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Newair ADS-300 Dehumidifier
4helpful
5answers
Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Top Danby Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Anonymous
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
