How to Fix Canon Printer Error Code U163:
1. First, you need to tap on the Canon Pixma MX328 Stop/Reset Button.
2. When a machine is ON, bring the refilled cartridges into a machine and cover the top part of device equally with scanning unit cover.
3. Now you have to wait for few seconds until error displays. And if an error code is not displayed then start printing, to show the error code in LCD display panel.
4. While using the device if you see the errors then carefully click and grip Reset/Reset button. Don't free the button until printing machine restarts automatically.
5. At last your machine will start successfully, and you can free the button.
Note: It Is Suggested by experts always replace the empty ink cartridge with OEM cartridge.
www.fixya.com > Forum > Tags Find solutions to your singer sewing machine error code e5 question. Get free help, tips & support from top experts on ... Singer 3116 Simple. 887 Questions ...
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
You could try cleaning the one on there, but all brothers similar to yours are plagued by this problem.
To clean it try:
SWITCH MACHINE ON WHILST HOLDING DOWN MENU/SET KEY, THIS PUTS MACHINE INTO FACTORY SETTINGS MODE. (MAINTENANCE WILL SHOW ON LCD) ENTER CODE:84 & WAIT WHILE MACHINE PERFORMS A FORCED CLEANING CYCLE. (cLEANING WILL SHOW ON DISPLAY) NOW ENTER CODE:09 & MACHINE WILL PRINT OUT ITS PRINT QUALITY CHECK SHEET. (IGNORE INSTRUCTIONS PRINTED ON CHECK SHEET) CHECK QUALITY & REPEAT BY USING CODE:84 IF NEEDED. (YOU MAY HAVE TO DO THIS SEVERAL TIMES BUT YOU SHOULD SEE A STEADY IMPROVEMENT WITH EACH CLEANING CYCLE)
WHEN FINISHED AND QUALITY IS GOOD, ENTER CODE:99 TO RETURN TO STANDARD MODE. PRESS MENU/SET 4, THEN MONO FAX START TO PRINT OUT PRINT QUALITY CHECK SHEET & FOLLOW ON SCREEN INSTRUCTIONS.
