Canon i-SENSYS LBP6750dn A4 Mono Laser Printer Page Printers Mono A4 Logo
A
Anonymous Posted on Jul 19, 2014
E012 error Eo12-0001
Victorman
Level 3:
  • Canon Master 846 Answers
  • Posted on Jul 19, 2014
Victorman
Canon Master
Level 3:
Answers
846
Questions
0
Helped
315915
Points
2441
Its more than likely your black drum has seized or the tape from the toner cartridge was not fully removed and has found its way into the drum.. This will not allow the main motor to rotate hence this error.
See if you have an old drum and try it. It does not matter about print quality , you just want to see if the error goes away. The DC Controller circuit board provides the power to the main motor. There is a chance that that has failed but its more than likely something simple like the black drum.
1 Related Answer
color_50
color_50
  • 22 Answers
  • Posted on May 07, 2009
SOURCE: error e012-0001 problem
It is a Drum Drive system over load/ or Drum Motor issue/ DC pcb issue. Need to check drum blades for all colors or if Dev. units are locked up.
1helpful
Please explain me the error code of Duplo DP A100 printer the error code is: E012 cordially thank you
You may need a maintenance kit . Check right side interlock It my be broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
I am using a SE-S300 and can not clear an E012 error code!! any ideas????
Hi. Can you tell me what the rest of the message reads? Each error code has a message displayed as well.
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Fixya forum
what is solution
2helpful
Error
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
info@setobemmel.nl
My irC-3200 cannon just show me this error E012 number on the display screen so i want to know what this code mean??Please help me
E012-0001 Error code At about 37 sec. after the power is turned ON, due to a drum ITB motor failure
Symptom About 37 sec. after the power is turned ON, E012-0001 is displayed due to a drum ITB motor failure. Cause Rotational failure of drum ITB motor Items to Check 1) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR, enter 1 and press the OK key.
2) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR-ON, press the OK key to check whether the motor is working normally.
3) Check whether 24V is supplied to J93 on the ITB drum motor. If yes, the ITB motor likely faulty.
4) If 24V is not supplied to the ITB drum motor, check whether 24V is output from fuse PCB J70-3 to the ITB drum motor.
Also, check whether 24V is output from the fuse PCB J71-1 to the microswitch PCB and also whether 24V is supplied to the fuse PCB J71-2 from the microswitch PCB.
5) If there is no problem between the fuse PCB J71-1, -2 and the microswitch PCB, the fuse PCB is likely faulty.
If 24V is output from the fuse PCB J71-1 to the microswitch PCB and not supplied to the fuse PCB J71-2, check the microswitch PCB. Field Remedy Replace the drum ITB motor.
FH6-1971 DC Brushless Motor
1helpful
E 00012 Error
E012-check your drum unit /drum drive sometimes stucks up
Error e012-0001 problem
2helpful
Paper jam and error code e012 on ir6000
You could very well have a worn registration clutch, it's behind the the gray roller that sits to the right under the drum. Good luck! If that doesn't do the trick you may have to change your transfer settings in service mode
2answers
Need help
I guess I have to use my psychic powers to see what machine it is.....................................................................................
Canon ...........E020 toner feed problem
E012..................?????? ( not in the canon error code list........E010 & E011 Drive problem)
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
