Sewing Machines Logo
A
Anonymous Posted on Aug 18, 2014
E6 error code - Brother Sewing Machines
Error stuck on rewinding bobbin ][
Question edited for clarity. It is a 'bobbin', not a 'bobbing'.
Is it E6, E7, E4, or is it E674? But the main problem, NO Make and Model. Just Google the Error code like this with make and model before it Margaret.
https://www.google.com/search?q=E674
I have a Brother XR9500prw, Error code E6 came on the screen. I did top thread again. No tangle so I continue to input numbers for the lettering font. The machine will do nothing. How do I fix this?
Q: What does E6 error message mean? A: The motor locked up because thread is tangled Q: How to fix E6 error message? A: Do the following:
  • The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
  • Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
  • The needle could be bent. Replace the needle making sure the flat side is facing the back.
Error message e6. Needle won't move
Check your owner's manual - troubleshooting section. Sometimes it will show the error codes. Otherwise, search the internet for:
Make + Model + "error code E6"
You can also check with the manufacturer.
E6 error code on cs6000i
it's possible that it's a mechanical or electronic problem or something has worn or is loose, it needs to be serviced
3answers
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
1helpful
Brother sewing machine screen displays E6
E6 is an error code. You didn't state the model number, but if you look in your instruction manual, it will list the error codes. If you don't have a manual, go to Brother.com and you can get the answer.
Top Brother Sewing Machines Experts
Paul Bade
Rommel Balcita
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
