Washing Machines Logo
A
Anonymous Posted on Sep 02, 2014
Error code f35
After replacing water level switch I still get F35 error code
qvo523
Level 2:
New Friend:
  • Expert 122 Answers
  • Posted on Sep 02, 2014
qvo523
Expert
Level 2:
New Friend:
Answers
122
Questions
0
Helped
31180
Points
285
Too much detergent or wrong kind of detergent. If you use non HE detergent this will happen. You can remove the excess suds by running a cleaning cycle and adding cooking oil. The detergent will attatch itself to the oil and remove all soap residue, add an extra rinse to the cycle. Also run it empty.
5 Related Answers
Anonymous
  • 44 Answers
  • Posted on Jun 10, 2009
SOURCE: F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Anonymous
  • 1902 Answers
  • Posted on Feb 13, 2009
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Anonymous
  • Posted on Jun 13, 2009
SOURCE: Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
Anonymous
  • Posted on Aug 13, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Anonymous
  • 15935 Answers
  • Posted on Sep 25, 2010
SOURCE: Sears Kenmore HE3 Error Code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Top Maytag Washing Machines Experts
jdthefixer
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
