Washing Machines Logo
A
Anonymous Posted on Sep 02, 2014
Replace pressure switch
Relaced pressure switch, checked behind rubber boot, and cleaned drain plug but continue to get f35 error code
qvo523
Level 2:
New Friend:
  • Expert 122 Answers
  • Posted on Sep 02, 2014
qvo523
Expert
Level 2:
New Friend:
Answers
122
Questions
0
Helped
31180
Points
285
The F35 error is for a suds problem, wrong kind of detergent or too much. If this does not fix it, replace pressure switch. It is located on the rh side, at the rear. Remove the top panel by removing 3 1/4 inch screws or t20 torxs at the back of the panel. After you remove the screws the panel should slide back. It is a brown and black switch with 1 connector and a black rubber hose at the bottom.
5 Related Answers
Anonymous
  • Posted on Dec 11, 2007
SOURCE: Duet error code F 02.
Just had this problem. Remove the kick plate in front of machine. The drain pump filter maybe clogged. Turn the white screw to remove filter, but be sure to have towels or a bucket handy. I clean mine out and now is working fine.
Anonymous
  • Posted on Mar 20, 2009
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Anonymous
  • 44 Answers
  • Posted on Jun 10, 2009
SOURCE: F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Anonymous
  • Posted on Jun 13, 2009
SOURCE: Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
Anonymous
  • 15935 Answers
  • Posted on Sep 11, 2010
SOURCE: error code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Top Maytag Washing Machines Experts
jdthefixer
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
