Control PWB - Operation panel PWB communication error. You might have a bad operation panel or the connector to the panel may be loose. communication error
This F00 code indicating a Drive Motor Tachometer Error. The control is unable to
properly detect motor speed and the machine will shut down. If a failure
occurs during high-speed spin the door will be unlocked after 3
minutes.
Potential Causes: - Check wire
harness connections between the Drive Motor/Tachometer and the Motor
Control Unit (MCU), and between the MCU and the Central Control Unit
(CCU) - Check the Drive Motor - Check the MCU - Check the Wire Harness
Begin
troubleshooting right at the motor. Remove the back
panel and unwind the belt from the drum pulley. Now turn the motor
pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you
have a bad motor.
minutes.
Potential Causes:
- Check wire
(CCU)
- Check the MCU
Begin
have a bad motor.
