LG WM2455HG XL Front Load Stackable Washing Machine with 9 Washing Programs Logo
A
Anonymous Posted on Sep 13, 2014
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
I have drained drum from hose on front panel. It will not rinse, spin and drain my blanket. Cleaned all drains. I hear the hum of the pump.
Alex
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on Nov 26, 2014
Alex
Expert
Level 2:
Champion:
Answers
207
Questions
Helped
58985
Points
299
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
5 Related Answers
Anonymous
  • 1543 Answers
  • Posted on Mar 18, 2009
SOURCE: where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
FitzOriginal
Chris Hall
  • 842 Answers
  • Posted on Mar 26, 2009
SOURCE: My washer won't spin & drain
Well, you have covered the usual reason for a no drain (and of course it won't spin if it wont drain because it's meant to stop the spin if there's water still in there). It sounds like the empty pump has failed. Can you hear it whirring on the empty cycle?
If you get under the machine and locate the pump, most have a fan-like assembly you can grab hold of and turn manually, occasionally this will free the pump up if it has something caught in it or the bearings are a little stiff. Next step is to remove it and clean it out, then run it on the bench and check it works. You will either fix it, or know that it's dead and have to get a new one at this point
Anonymous
  • 82 Answers
  • Posted on Jan 22, 2010
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
Anonymous
  • 500 Answers
  • Posted on Feb 16, 2011
SOURCE: Got an LG front load washer WM2277HS with an error
Replace the Drain Pump. Its very cheap to replace, so do not worry. The impeller magnet was most likely damaged by a small object or normal wear & tear,
If you want to be sure, first remove it and attach power to its 2 pins.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Testimonial: "You saved me!!!!! I would have never figured this out without your help."
Anonymous
  • 106 Answers
  • Posted on Mar 04, 2011
SOURCE: Front Loader LG Inverter 7.5kg model WM-12330 FB
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Top LG Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
