I have a copystar with a E07 code it only print 1/4 of the page then gives me an E07 code.
SOURCE: C710 Code on Copystar 2030
Did you disconnect telephone line?
C710 : Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
C710 Toner sensor problem
• The sensor output voltage is outside
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
SOURCE: Copystar CS-1810 Error Code
I have code c620 showing up on my copystar 1810. Anybody have an easy fix so I dont have to take in to shop.
SOURCE: Unrecognizable error code
call kyocera support... you are having a serious problem
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
