LG WM2688H Front Load Washer Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code tE - LG WM2688H Front Load Washer
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Jul 07, 2009
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
764190
Points
5690
TE is a thermister error. (temperture sensor) Located at the water heater element.
I have a TE code on my Samsung washing machine. I replaced the part it said to and I am still getting the TE code please I really need the washing machine working
A Samsung Washing Machine displays a tE error code when a Thermistor Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-washing-machine-te-code/
Error code tE
if you replaced the thermister
and tE comes up
then its the heating element has failed
and or its thermal safety fuse set up perhaps failed also
2helpful
3answers
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
1helpful
2answers
Samsung NE595N0PBSR range is giving error code "tE"
te error code is (touchpad error). you have to replace the touchpad assy. the board and overlay.
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
2answers
1helpful
2answers
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Lg rom reads error code te
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
6helpful
2answers
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
Top LG Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
