Computers & Internet Logo
A
Anonymous Posted on Mar 14, 2015
How do i Disable software
Disable software?
Geof
Level 2:
Sergeant:
  • Expert 120 Answers
  • Posted on Mar 14, 2015
Geof
Expert
Level 2:
Sergeant:
Answers
120
Questions
Helped
22055
Points
910
Which computer are you working with? Most times you can either go to task manager then services, Or type MsConfig into the search and go to startup items.
Google not working internet stop working
Method 1 : Reset Internet Explorer
  • Open Internet Explorer.
  • Click on Tools menu (Press "alt" key to active menu bar).
  • Click on "Internet Options". a configuration window you will appear
  • Click on advanced tab.
  • Click on "Reset" Button. You'll get an another box, here check a box named as "Delete Personal Settings", then click on Reset button on it.
Method 2 : Disable Software Rendering. Disable Hardware Acceleration option in IE 9 & IE10
  • Un-check a option named as "use software rendering instead of GPU rendering". it is located under "accelerated graphics".
Method 3 : Disable 3d in "NVIDIA Graphics driver" Disable "stereoscopic 3D" option into "NVIDIA Graphic driver" application. (If you have Nvidia Graphics Drivers & Software, If you don't have the you can leave that step)
  • Open Nvidia software from system tray.
  • Disable the option named as "stereoscopic 3D" from NVIDIA Drivers (NVIDIA driver is a computer Graphics drivers their software runs on system tray. )
Cannot connect to google chromeinnternet
- Disable Sandboxing Mode.
- Check if Incognito Mode Works Fine.
- Disable Ad-Filtering Programs.
- Repair Chrome Registry With Reginout.
- Remove Chrome Default User Profile.
- Disable Integration with Download Manager Programs.
- Disable Integrated Version of Shockwave Flash Player.
Google chrome unresponsive
- Repair Chrome Registry Configurations and Settings (must use reliable program Reginout for it.)
Scansnap error 0x80210026
Hi There
1.Have you logged in with an administrator account?
2.Was it working fine earlier?
3.Were there any recent changes made on the computer prior to the issue?
You may receive this error if you don't have the appropriate permissions to use the scanner.
Let's try these methods and check if it helps.
Method 1: Install ScanSnap Manager Update (S1500) and check.
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
Method 2: Disable security software and check.
http://windows.microsoft.com/en-IN/windows7/Disable-antivirus-software
Warning: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you should not disable your antivirus software. If you do have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you are connected to the Internet or a network during the time your antivirus software is disabled, your computer is vulnerable to attacks.
Method 3: Uninstall and reinstall ScanSnap and check.
http://www.fujitsu.com/downloads/IMAGE/manual/trouble/p3pc-3792-03enz0.pdf
I want to disable my account
You enter your account to disable it. It is on your setting of your account. If you get problem to disable it, contact the service support of symantec.
2helpful
2answers
I want to instal a web cam and I am told to disable spy ware and anti virus does this mean I have to deleteit?
Is the software what came with the web cam ? or is it downloaded software. if its an instalation cd then yes disable whilst it installs and then re enable them. all disable does is deactivates the software temp - you have no need to remove or delete.
Can not update software
Most likely the firewall on you security software is causing the problem. If you know how to disable it open your security software and turn off the firewall. After updating the software, turn on the firewall again.
If you are not able to do the above steps. We will have to disable it from MSCONFIG.
Click start – Run – Type “msconfig” – Hit enter
Click on the Tab “Startup” on the top, Click “Disable All” button
Click on the Tab “Services” on the top, Put a Check on “Hide All Microsoft Service” , Click “Disable All” button
Click OK.
Restart the computer and try updating the software now. It should work. Once updated, open msconfig again and select “Normal Startup” to reset it back to the default settings again.
When I try to install my 8300 series Lexmark printer to my compaq presario with a windows vista operating system I get an error message that sais I have to disable my anti-virus software before I continue....
FIRST you go to your ANTI-VIRUS program , go to PROPERTIES , there your gonna see a window and where it says ANTI VIRUS enable or on , just click to disable it , i cant be more helpful cause I dont have the brand of your anti virus software , hope this helps AJ
2helpful
Installation
hello jonesyb,i am nichu .i, have a solution for your problem.is it necessary to disable anit virus software before installation because your antivirus software blocks the installation thinking it as a virus.though the software gets installed it might get corrupt.
to disable a antivirus software go to the system tray which is at the bottom right of your screen,right click on the antivirus software icon,then click quit or exit .............problem solved
take care
bye.
3answers
Cant download kodak easyshare software
If you have a firewall up, disable it than try to download the software.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
