Lands Phones Logo
g
grayson roberts Posted on Jun 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I turn do not disturb off - Comdial Lands Phones
Level 3:
  • Comdial Master 6,751 Answers
  • Posted on Jun 23, 2015
Cindy  Wells
Comdial Master
Level 3:
Answers
6751
Questions
0
Helped
3613921
Points
21938
With the Comdial Impact 8012S and a few other models, the DND feature is toggled on and off through the menu system as follows:
1) Select Options (the right-most button below the LCD screen)
2) Press Next (use that right button again) until DND appears as the current option.
3) Select DND (by pressing the left-most button).
4) Select OFF (by pressing the middle button).
5) Select Exit (the right-most button, again)
6) Press Speaker to end the programming mode. The speaker button is on the body of the phone towards the right and bottom of the keypad. The exact position depends on the model.
I hope this works for your model as well. If it doesn't, please add a comment with the model of your phone.
2answers
Iphone 5 won't alert me to texts or calls
go to settings-> do not disturb and make sure do not disturb is off, you can also check to see if do not disturb is on by seeing if there is a moon in your status bar
Reset Do not disturb
Question is kind of Vague, so I'm assuming you are trying to turn off the Do Not Disturb (DND).
In the standby mode, press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again.
Hope that helps.
1helpful
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
2helpful
2answers
Phone set on do not disturb can not undo
For GE 6.0: There is a button on the base (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz: 1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Do not disturb is on and i dont know how to turn it off
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
2helpful
Taking off Do Not Disturb
For GE 5.8 GHz:
Hope this helps!
Do not disturb
For GE 5.8 GHz:
Comdial Impact 24/48/72 phone
You can try the below steps in order to turn off Do Not Disturb. For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
Top Comdial Lands Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Andrew
ADMIN Andrew
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
