Canon imageRUNNER 2520 Laser Multifunction Printer Logo
abhijit shrestha Posted on Aug 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have getting error code E000020. - Canon imageRUNNER 2520 Laser Multifunction Printer
Maurice Botha
Level 2:
Habit-Forming:
New Friend:
  • Expert 21 Answers
  • Posted on Dec 05, 2015
Maurice Botha
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
21
Questions
0
Helped
4212
Points
137
E020 The path between the sub hopper and the developing assembly is clogged with toner.
0000 The developing assembly toner sensor
detects the absence of toner, while the
sub hopper toner sensor detects the
presence of toner. With the developing
clutch turned on, the hopper feedscrew
motor is rotated for 1 sec intermittently
194 times; still, the developing assembly
toner sensor does not detect the presence
of toner.
Replace the developing assembly toner
sensor. Replace the sub hopper toner sensor.
Replace the DC control PCB
5 Related Answers
Anonymous
  • 287 Answers
  • Posted on Jan 05, 2008
SOURCE: Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
color_50
color_50
  • 22 Answers
  • Posted on May 07, 2009
SOURCE: Error code: E000020-03b0
Replace the Cyan Drum !!!!!
1234567890mi
  • 58 Answers
  • Posted on Aug 07, 2009
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Anonymous
  • Posted on Aug 21, 2009
SOURCE: error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Testimonial: "very helpful"
Anonymous
  • 168 Answers
  • Posted on Oct 12, 2009
SOURCE: for canon 3220 error code E000020-04b0
replace the black drum
1helpful
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
1helpful
2answers
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
7helpful
2answers
Error Code - E000020-02a8
e000020-02a8 and e000020-02a2,these errors are coming in my copier 3100 how can i resolve this errors.it will be very thankful if u get me out of these errors.
27helpful
2answers
Error code E000020 - 0081 in ir C3170 PCL5c
3helpful
17helpful
3answers
Error code E000020-01b0, E000020-0260
drums need replaced
4helpful
65helpful
7answers
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
