Computers & Internet Logo
A
Anonymous Posted on Oct 12, 2015
How do iactvate java script? - Computers & Internet
Erin Wood
Level 3:
  • Master 652 Answers
  • Posted on Nov 21, 2015
Erin Wood
Master
Level 3:
Answers
652
Questions
0
Helped
214336
Points
2583
Google Chrome
  1. On the web browser menu click on the "Customize and control Google Chrome" and select "Settings".
  2. In the "Settings" section click on the "Show advanced settings..."
  3. Under the the "Privacy" click on the "Content settings...".
  4. When the dialog window opens, look for the "JavaScript" section and select "Allow all sites to run JavaScript (recommended)".
  5. Click on the "OK" button to close it.
  6. Close the "Settings" tab.
  7. Click on the "Reload this page" button of the web browser to refresh the page.
Internet Explorer
  1. On web browser menu click "Tools" icon and select "Internet Options".
  2. In the "Internet Options" window select the "Security" tab.
  3. On the "Security" tab click on the "Custom level..." button.
  4. When the "Security Settings - Internet Zone" dialog window opens, look for the "Scripting" section.
  5. In the "Active Scripting" item select "Enable".
  6. When the "Warning!" window pops out asking "Are you sure you want to change the settings for this zone?" select "Yes".
  7. In the "Internet Options" window click on the "OK" button to close it.
  8. Click on the "Refresh" button of the web browser to refresh the page.
Internet Explorer < 9
  1. On web browser menu click "Tools" and select "Internet Options"
Mozilla Firefox
  1. In the address bar, type about:config and press Enter.
  2. Click "I'll be careful, I promise" if a warning message appears.
  3. In the search box, search for javascript.enabled
  4. Toggle the "javascript.enabled" preference (right-click and select "Toggle" or double-click the preference) to change the value from "false" to "true".
  5. Click on the "Reload current page" button of the web browser to refresh the page.
Opera
  • 1. a) Click on "Menu", hover mouse on the "Settings" then hover mouse on the "Quick preferences" and mark the "Enable Javascript" checkbox.
  • 1. b) If "Menu bar" is shown click on the "Tools", hover mouse on the "Quick preferences" and mark the "Enable Javascript" checkbox.
Apple Safari
  1. On the web browser menu click on the "Edit" and select "Preferences".
  2. In the "Preferences" window select the "Security" tab.
  3. In the "Security" tab section "Web content" mark the "Enable JavaScript" checkbox.
  4. Click on the "Reload the current page" button of the web browser to refresh the page.
How to enable JavaScript in your browser
1helpful
How do I go about downloading java script?
Java script is native to all browsers. You may have it disabled. You will have to go into your browsers settings and enable java script within your browser. If you have any plugins such as "No Script" then you will need to disable them or uninstall them for Java script to work properly again.
If you meant to ask how to download Java (it is different than java script) then you would visit http://www.java.com and download the software and install.
Seeing as you posted this as a Facebook problem I would be satisfied to say that your problem is java script is disabled in your browser settings.
2helpful
2answers
Unable to access jarfile c:\Program Files\Java\jre6\lib\librtexec.jar
sounds like this would be a java-script error. you can try re-install java-script http://www.java.com/en/download/ it might be a good idea before you re-install, to uninstall any instance of java from the control panel - add/remove programs, or programs and features section for vista/windows 7
I can't see my writtings on yahoomessenger
You may have scripting disabled in your Internet Explorer.
To enable scripting:
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messeng...
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Enablin javq scriptcan't figure out how to get it to work
To enable JAVA:
Internet explorer 6:
1. Select Tools from the top menu
2. Choose Internet Options
3. Click on the Security tab.
4. Click on Custom Level.
5. Scroll down until you see section labeled Scripting.
6. Under Active Scripting, select Enable.
7. Click OK to save changes.
8. Close and restart Internet Explorer.
Internet explorer 7:
1. Open your browser.
2. Click on Tools button (it is located in the upper right part of the screen)
3. Select Internet Options.
4. Click on Security tab.
5. Click on Custom Level.
6. Scroll down until you see section labeled Active Scripting.
7. Select Enable and click OK.
8. Click OK to save changes.
9. Confirm Yes and click OK.
10.Close and restart the browser.
Enable the Sun JRE though your Web browser:
1. Click "Tools" --> "Internet Options"
2. Select the Advanced Tab, and scroll down to "Java (Sun)"
3. Check the box next to the Java version
4. Next, select the Security Tab, and select the "Custom Level" button
5. Scroll down to "Scripting of Java applets"
6. Make sure the "Enable" radio button is checked.
7. Click OK to save your preference.
How do i install java script being a guest
java script is not an installalbe item. java script is run inside the browser.
2helpful
2answers
I am yhabing a problem thaat i cannot open utube
download the lastest flash playe and latest java, instructions here to make sure everything is turned on
http://tinyurl.com/yd64pt2
2answers
How i install js script software
Java-script is a scripting language interpreted by you browser and is not installed on you PC like compiled software. Java, which is a programming language is installed by downloading JRE for www.sun.com.
If you browser is not running Java-script while viewing web-page, (eg: youtube) that is in you browser options, you probably need to enable JS in you settings. google "enable javascript YourBrowserGoesHere".
1helpful
Firefox and Java
You probably need to go in to your options and allow java script.
When visiting a site such as Friends Reunited I cannot view the site as I keep getting a message up with a yellow exclamation mark in a triangle saying: Error in addLoadEvent:(object error). I have typed...
It appears to be a Java script error.
The chances are some pages your are visiting are using Java script to deliver multilayer messages or adverts.
If you didn't have Java script installed on your machine you would get an error along the lines of "page was unable to load" so I am guessing your Java script needs updating.
Go to this site: http://www.java.com/en/ you can either download Java or have the site check your computer to see if it has the latest copy(easiest method).
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
