Photography Logo
Error code?? camera shows error code and makes a long noise when turned on
4 Related Answers
Anonymous
  • 104 Answers
  • Posted on Mar 24, 2008
SOURCE: ERROR CODE E63:20
sir E63 ERR is related to lens err ur camera lens unit dislocated or gears problum. this is easyly repairable
Misty Hoffman
  • 374 Answers
  • Posted on Mar 30, 2008
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Anonymous
  • 7 Answers
  • Posted on May 13, 2009
SOURCE: My camera is showing the error code E:61:00
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Kiln Man
James Pasek
  • 5 Answers
  • Posted on Jan 01, 2010
SOURCE: camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Photography Expert? Answer questions, earn points and help others
