Pool & Spa Logo
j
joy sexton Posted on Apr 16, 2016
Octagonal Intex 28453E Pure Spa Jet & Bubble Deluxe is flashing error code 99 anybody know what this means?
5 Related Answers
Mike Tellegen
  • 1631 Answers
  • Posted on Apr 11, 2015
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Bill Boyd
  • 53816 Answers
  • Posted on May 22, 2015
SOURCE: In need a inlet/outlet o ring for pure spa. Dealing with intex, directly the product is out of stock and they dont know when it will be in.
go to a bearing supply shop as they have "O" rings of many sizes
take yours as a sample
make your own "O" ring kits available.
find a seal and "o" ring shop and there are kits that you can get to make your own "O" rings
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: I tried intex corp to get an o ring for pure spa, but they are out of stock. Wondering if anyone knew of retailer of intex who sold parts
funny,they have them now,
Spa Control Station Air Inlet Ring Replacement Parts Spas Store Intex
beau story
  • 108 Answers
  • Posted on Jun 05, 2015
SOURCE: I've got an Intex pure spa hot tub and the air bubbles button isn't working but the LED screen is on??? Any suggestions?
  • Do the other buttons work fine?
  • Did you press REALLY hard and break it
  • Have you tried pressing it REALLY hard when its not broken- Probably a bad idea
  • if you have the know how and the bravery take the face plate off (MAKE SURE THE POWER IS OFF AND THE WHOLE THING IS UNPLUGGED)!!!!!1
  • check the wires going to the back panel of the screen Rusted, corroded? Might be covered under warranty - refer to manual or look-up based on how long you've had unit
skythemike
Matt Davis
  • 3 Answers
  • Posted on Aug 12, 2015
SOURCE: I keep getting a E96 code on my intex pure spa and
RE: INTEX PureSpa - E96 error code.
This also happened to me, just after having it for 1 year. I followed the scanty instructions in the troubleshooting section to no avail. I called for "technical assistance" twice and got random females with heavy Asian accents and absolutely NO technical know-how.
ME: "I got a E96 error code."
AL (Asian Lady): "When you buy it? If less than year, we send new base."
ME: "It's been longer than that, can I just buy the base then?"
AL: "Yes, $380 and we send it you."
ME: "But I paid $350 for the whole thing new!"
AL: "It's cheaper just buy new one."
ME: "Sure, but can't we troubleshoot this one?"
AL: "We can no more troubleshooting."
No supervisor was available, I was told to hang up and try again for someone else. Persisting, I pried info from one that it was "pump bloken," from the other "bad consore." I believed both were full of it and had no idea what they were talking about.
MY FIX: I disconnected unit from spa. Removed console from base. Turned base upside down to inspect pump and find any ID markings. Found no obvious problem with pump or heating mechanism. Spend few hours time researching cost to buy identical pump. Gave up. Returned to unit, reassembled it, and it worked perfectly!
MORAL TO THE STORY: Intex products are fine, their Tech Support is a joke. I suspect the console had detected air in the pump and that it was stuck in a system error cycle which required a prolonged rest from any power input to refresh. Also, turning the unit over (while inspecting it) may have flushed any remaining water around the onboard pump sensor.
Don't listen to their know-nothing "tech support" when they suggest it is a GFCI problem, (or some of the others here who give this advice without really knowing).
Just keep it fully unplugged for at least a few hours to wipe the system memory!
Since it's a circuit board, it's like a mini-computer. Actually, it's just like a modem that requires resetting. If you unplug it and then replug it too soon, you've solved nothing, the on-board circuitry retains enough voltage to prevent it from resetting. You need to keep it unplugged for an extended period of time.
Hope this helps. Best of luck!
-Matt
Top Pool & Spa Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Pool and Spa Expert? Answer questions, earn points and help others
