J
Jubayer Al Siddique Posted on Nov 24, 2016
What's C01 Code - Toshiba 2060 Copier
Alben Balinong
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 53 Answers
  • Posted on Dec 01, 2016
Alben Balinong
Contributor
Level 1:
New Friend:
Cheetah:
Answers
53
Questions
Helped
13188
Points
73
C01 is main drive not working.
2answers
Wfmc3200 run diagnostic and see e20 c01 and d10 c01 codes. Bad motor or something in the drum support?
E20 error code: Short or break causing incorrect resistance in winding of the circulation pump or the motor.
D10 error code: Cause: Wiring/electrical fault related to motor triac.
Action: Check wiring on/to PCB and motor. Check the triac (on the PCB).
C01 error code: Cause: Motor tacho fault.
Action: Check motor and motor tacho wiring for problems.
2answers
How can I fix an error code 'c01-563' on Riso RZ370
Changing the ink tube or the RFID chip on the ink tube may solve your problem.
PrntNow.com
1helpful
I'am looking for free service manuals forTechnics ST-C01, SU-C04, M07
this link will give you the service manual of st-c01. If you need more manuals they are accessible at this website also. Good luck!
Thanks,
gylacz
Canon DR 6080 Error Code C01
The top cover is held in position by a small piece of plastic on both sides. Open the Left hand side cover and you will notice the catch with two screws. Unscrew them slightly push it down and tighten again. This should solve the problem.
S. Mohan, India
I am looknog for a battery replacemnet for Spectroniq TPL C01, the part number is BP C01, Where can I find it?
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=bp-c01+for+tpl-c01&x=0&y=0&ih=6_6_1_2_2_1_0_1_0_2.61_162&fsc=-1
I have a C01 error on my scanner. From what I can
C01 is 'Cover open'. Ensure that the top cover is closed fully.
S. Mohan
1helpful
Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
C code 00
P00 is paper/document already present in the Scanner and scanner not initialised. You will heat two beeps. Open remove all shred os paper. C01 is cover open, close it firmly
S. Mohan, India
1helpful
2answers
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Top Toshiba Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
