Kenmore Humidifier Model 758.15412010 I have discovered a way to activate the service display codes but can't figure out how to reset the controller.
SOURCE: the water refill icon keeps blinking, but the humidifier is full
have you checked the water sensor?
SOURCE: Kenmore 15408 Humidifier How to Reset CF
Per the owner's manual, you simply unplug your device for 30 seconds. Upon plugging it back in, the CF notification should be cleared.
This assumes you have also changed the filter, of course.
SOURCE: reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
SOURCE: aprilaire humdiifier not working
Does your humidistat have any dip switches or a small jumper wire? if it does try switching positions of the jumper or change dip switch. hope this helps
SOURCE: Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
