SOURCE: motor brush spring broke
Try this site: I hope this works for you. http://www.rotozip.com/GetSupport/AskandAnswer/Answers/PartsRepairs
Best regards Michael Mittelsdorf
SOURCE: I am missing the key to the gun lock and I cannot open it.
Unfortunately you didnt tell me what kinda of lock this is.
IE 1) Trigger Lock 2) Cable Lock
Now from what i understand about them, for 1 unless you spent high end dollars on your lock its a piece of garbage anyway. Read this page
First method id try is "bumping" (this is going to be the cheapest method for you without resorting to a locksmith or destruction of the lock.
"Bumping" involves using blank keys to effectively pick locks. Watch this You Tube Video
In order for you to try this you would have to go to the place that sells your model gun lock. ask them if they have extra keys, if not i know locks that tend to be simple (4 pin locks like trigger locks) dont have that many combitnations and if you went through 20 boxes (if you are able to do this at a local store) you WOULD find a key to use that would fit yours.
NOTE if you cannot obtain a key blank @ the local shop go to the local locksmith shop, tell them you want a blank for it, see if they can provide it (i have no clue) (most likely though unless its one of those insanely weird key types)
2) Still a cheaper method would be probably to destroy the lock (irregardless of this locks price, scope out a new lock and see how much that would cost and call a locksmith and ask what picking and re key ing your lock would cost)
3) You could if in the right area of the world, obtain your own lock pick set ( a simple set will work here), and pick the lock yourself. LESSON to pick a lock you a few tools and will always be using 2 @ a time.) for 1 you need a tension wrench this is a tool that allows you to apply tension into the inner cylinder (imaging when you spin your key what way the key spins, you need to apply force in that direction) NOTE just a little bit. the reason for this is it creates a pinching zone inbetween the two cylinders in the lock (the pins are what bind them together). With the right pressure on the cyclinder with your torque wrench you can "rake" the pins (scrape them up) hoping that as they go up they dont come down. (NOTE some pins have 3 pins and fake pins and are set up in a way that makes them hard to pick try and determine which pins are longest first)
For more informaiton on this i can be contacted it should be a matter of enough rakes.
GL
Brad
Please Rate this as FixYa :)
NOTE when a lock is in the open position it is easier for a locksmith to fabricate a key :)
SOURCE: Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
SOURCE: Same problem. lid locks open. took appart.
Hey there buddy. The issue that you have is a clear hardware issue. Here are my recommendations. Is your printer still in warranty? If it is in warranty then just call hp and have them replace your unit. If it is not you can try going to best buys or walmart or any other hp partners and retailers and have them service the printer. However most likely they are just going to send the printer to hp and have it fixed there and I believe the charge will be higher. I had been an hp technical support and with hardware issue with your printer we do not recommend service or repairs, what we suggest is hardware replacement. And with your printer hp is no longer manufacturing that kind of model so i doubt if you can find any available parts for that. Here is my suggestion, if your printer is out of warranty already what you can do is call hp and ask for an upgrade. An upgrade is cheaper compared to getting a brand new printer of the same model with no difference in functionality and features. They call it upgrade because your printer is already obsolete and they are going to replace it with latest printers they have of the same family or series with your old printer. The good thing also with an upgrade printer, it will be in warranty and you will have a technical phone support and hardware support for one year. And if you decide to get another extended warranty from the same date of getting an upgrade you will get up to 70% percent on extended plans. So you decide which one best for you...
SOURCE: the spring part has gone
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
