I have a client who has Arrow Integrated Financial Software Version 4.20 This software is from Arrow Research Corporation This software runs on dos and windows There was an error printed on a report which said error #8235 DFSORT:log I have found a pdf from Arrow with the error codes and it is listed under Dataflex utility run time status which says 8235 sort stack overflow Does anyone know how to fix this Dataflex 8235 sort stack overflow error? The OS on the work stations is Win98 The network OS is Novell Netware 4.11 Thanks
SOURCE: Novell Netware Users Guide.
Netware is a very complicated operating system so the manual may not help if you don't have other Netware experience. Nevertheless, Network 4.1 documentation can be found at http://www.novell.com/documentation/nw4/docui/index.html
SOURCE: Broadcom 440x 10/100 Integrated Controller driver will not load
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
SOURCE: Problem configuring client station
easiest solution is to avoid their sync stuff all together, i've almost never gotten it to work correctly. what i generally do is set up the client station as a "stand-alone" and put the server address for the server name. that usually does the trick, only lick is that if the server goes down, your toast, the client goes down too.
SOURCE: Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
SOURCE: print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
