Air Purifiers Logo
C
Charles Gresko Posted on Sep 15, 2017
What is the problem with my Ionic Breeze Quadrant when a RED LIGHT comes on?
5 Related Answers
Anonymous
  • Posted on Jun 23, 2008
SOURCE: ionic breeze "GP professional
Thank you for responding. I am not interested in your offer.
Anonymous
  • Posted on Aug 26, 2008
SOURCE: my ionic breeze has quit
i have the same problem as well as my on button keeps going off and on...
Anonymous
  • 4 Answers
  • Posted on Apr 23, 2009
SOURCE: Sharper Image Ionic Breeze GP S1719
I just typed in an msg on how I fixed mine. Im an old lady, and figured what the......... cant hurt. so check my msg here somewhere, and start taking out the screws. good luck, in the last couple of hours, ive fixed two of them, just cleaning the contacts. good luck to you.
Anonymous
  • Posted on Apr 25, 2009
SOURCE: ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Anonymous
  • Posted on Aug 29, 2009
SOURCE: Ionic Breeze Repair
One drop of water on the blades will cause it to turn off. Make sure it is dry before reinstalling the blades. I wash mine before going to bed, dry, then let it sit till morning before reinstalling. Also the button that turns it on and off is not very positive you must push it hard. People think this thing is supposed to clean up very dusty air but it is not so good with heavy dust. What it is best at is clearing out smells from a damp moldy house. If you have a damp house you will love what it does. But if you have a very dry house that needs a humidifyer you might not like it. it produces some ozone, natures own dissenfectant, that naturally kills mold is why it is so good in a damp house. if I run mine on high all day I can smell the ozone if I have been away from the house. If the ozone gets to strong I just switch to a lower setting or turn it off a couple of hours. In a dry house the ozone can, if left on high to long cause your bronchial tubes to burn some. Ozone gets a bad rap, without it life in the south would not be possible mold and fungus would kill us all. As for hissing I have friends with them and some of them hiss louder than others but all hiss some. You can hear all of them on an AM radio. The powersupply will switch on and off to apply a charge to the blades the lower the setting the longer the off cycle. An AM radio will whine when the powersupply is charging the blades. I think the problems that Sharper Image had are due to a poorly written manual not informing users what to expect, and making claims that the unit cannot live up to. But in my damp moldy house it is wonderful. John
SHARPER IMAGE IONIC BREEZE QUADRA RED LIGHT ON
I had one that had the "needs cleaning" light was on. After cleaning, the light stayed on. I checked around at the time and learned it couldn't be fixed, and it was out of warrantee. I believe that's why they stopped making them. Mine was just thrown away.
No air flow in my ionic breeze model S1853. Just the light is on.
The Ionic Breeze filters air from the room into the front vents and releases ozone through the back vents back into the air. Some models you can put your hand near the back of the machine and feel a slight breeze. If you do not feel any air or the light that is on is red, the magnetic plates that capture the dust, etc. needs to be cleaned. Don't forget to turn the entire unit, after removing the magnetic plates, upside down to clear anything trapped near the bottom.
I have cleaned the machine and the red override light is still on
Are you sure the filter cartridges are in correctly.
Those can be tricky if they are not in exactly the same way. The metal tabs have to line up. Also, isn't there a reset button on those?
Hope that helps,
Matt
1helpful
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
2answers
Ionic breeze midi
Sharper Image Ionizers are no longer supported because they have recalled since they were proven to be innefective for cleaning the air and can harm people with breathing problems.
Here is a link on the Chapter 11 report
Here is an EPA report on ionizers
1helpful
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Top Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Air Purifier Expert? Answer questions, earn points and help others
