Televison & Video Logo
Nancy Shepard Posted on Nov 12, 2017
Ps3 Bluetooth remote control code list d o i can hook up to my magnavox tv
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Jan 30, 2008
SOURCE: need to find Code Lists for RCA universal remote
go here and search for your model of rca remote and there you go.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?kw=+RS1356+&area=&db=&br=&dv=&dt=&so=
Anonymous
  • 160 Answers
  • Posted on Dec 02, 2008
SOURCE: Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Anonymous
  • Posted on Jul 15, 2009
SOURCE: Radio Shack 3 in 1 remote code...
i need the codes for a radio shack 3in1 remote #15-2147 also the codes for an orion tv
Anonymous
  • 164 Answers
  • Posted on Aug 29, 2009
SOURCE: Silver Charter Communications Remote Control
1174,0062,0004,0009,0183,1133,0226,0288,0456,0008,0068,0075,0141
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Anonymous
  • Posted on Oct 19, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Top Magnavox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
vince
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
