Electrical Supplies Logo
J
Jesus Burgos Posted on Jan 09, 2018
Generator starts and runs perfectly but no electrical output. The reset buttons seem to be broken or loose. No other breaker switches are visible. Help
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Sep 19, 2008
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Anonymous
  • 585 Answers
  • Posted on Dec 17, 2008
SOURCE: Coleman Powermate 5000 reset problem
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
Anonymous
  • 86 Answers
  • Posted on Sep 10, 2009
SOURCE: generator motor runs fine, not getting electrical
You may have a bad cap or two on the inside
Anonymous
  • 205 Answers
  • Posted on Oct 13, 2009
SOURCE: No output
you need to replace your breaker frist. than check your rotor ohm and than your stator for shorts. you may want to check the cover were the bearing is there is a metal ring that may have came out and hits your brush cover. look for black burnt marks
Testimonial: "Thank you"
Anonymous
  • 251 Answers
  • Posted on Oct 20, 2009
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
