You need the installer code.
To program the delay time on a Simon 3 panel, navigate to the system programming menu by entering the installer code, then select "Timers" followed by either "Entry Delay" or "Exit Delay" to set the desired delay time in seconds; typically, you can access this function by pressing the "Settings" icon, then navigating through the menu options using the arrow keys. Key points to remember: Accessing programming: You will need the installer code to access the system programming menu. Menu navigation: Use the panel buttons to navigate to "Timers" and then select "Entry Delay" or "Exit Delay" depending on which delay you want to adjust. Time setting: Enter the desired delay time in seconds.
https://www.google.com/search?q=simon+3+panel+delay+time+programming
SOURCE: I was woundering how you
Hello, I have the Manuel for this particular system handy. If you are still looking for a solution, let me know. I will try and send it to you somehow
SOURCE: Can someone please tell me how to acces
Contact the Professor and will send you a manual.
AlarmProfessor.net
SOURCE: Simon3 entry & exit delay wont work.
It sounds like the door you are working with is progammed as a type 13 (perimeter) rather than a type 10 (entry exit)
Alarmprofessor.com
SOURCE: How do i get the
The alarm panel will only transmit data over a phone line. It is intended to call a central station. You could put your phone number in the panel, but all you would hear when you answered would be sounds similar to a fax machine. There are external voice dialers available that you could trigger from your panel that would call you with a recording.
The panelguides.com link below has many installation manuals for different DSC panels including programming information for your entry/exit delays. The link will take you to the DSC page. You'll need to look for the model of your panel, not the PK5501 keypad.
http://panelguides.com/panel-guides?task=viewcategory&catid=181
Hope this helps.
