Plumbing Logo
Posted on Aug 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you undo the clip connector that connects the Moen single-lever sprayer metal braided tubing to the faucet shank?
  • 1 more comment
  • morgan182 Aug 01, 2009
    I want to know how to remove the hydrolock adapter on a Moen wand hose assembly so I can tighten the shank with the tube wrench; then I will want to re-connect the hydrolock. Showing me a tutorial on how to put install the faucet does not help.
    So far 2 experts have pointed me to the exact same installation graphic from moen. I installed the faucet. I know how to install it. Whgat I DO NOT KNOw is how to REMOVE the hydrolock adapter to give me access to the shank, so I can tighten the nut. I.e., I need to DE-CLIP the hyrdolock adapter and I also need to know if it will then RE-CLIP.
    Pls elaborate on use of needle nose plus flat-head. What mechanism disconnects clip? Will it reconnect? This is not obvious...
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
  • Posted on Aug 02, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
Helped
121297
Points
551
First make sure the water is off at the wall befor you try this.try pushing the connector to the line ,thentake a smallscrew driverto push the inner tab or pry the outer tab(depending on the model)making sure the water is off and the faucet is open before doing this.hope this helps.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Aug 01, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3800740
Points
36075
Very small flat-head screw driver and a pair of needle nose should work well to grasp the the clip
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1203387
Points
12748
Try this link i think it is what you want
http://www.moen.com/consumersupport/installation/moen0106/moen0106.cfm
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1033831
Points
10054
To view a multimedia demonstration of this tutorial, click here.
The demonstration requires Macromedia Flash 4 player. If you don't already have it, click
here to get it.
Or you may try to go HERE, and see if this the type that you have.
Update me again here.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
