Home Logo
Karen Cuzner Posted on May 20, 2018
Uberhaus dual flush toilet keeps running - Home
5 Related Answers
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Jan 28, 2009
SOURCE: I purchased a Toto Aquia
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Anonymous
  • 49 Answers
  • Posted on Sep 20, 2009
SOURCE: have a vitra dual flush toilet we have no water
check to make sure the water level in your tank is sufficient, if not you'll need to ajust your float. otherwise your flapper is shutting too soon, you'll need to shut the water valve off and flush untill the water in the tank is gone, letting air back under the flapper slowing it's desent when submerged. then turn the water back on. if the problem continues repace the flapper.
Anonymous
  • 1922 Answers
  • Posted on Oct 13, 2009
SOURCE: running toilet
your float is stuck
Anonymous
  • 145 Answers
  • Posted on May 18, 2010
SOURCE: Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
woobie dog
woobie dog
  • 1273 Answers
  • Posted on Jan 16, 2011
SOURCE: How can we stop our
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Top Home Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Home Expert? Answer questions, earn points and help others
