SOURCE: JVC KD-PDR30 remote switch wire
hi sounds like theunit is faulty, you will need to have the unit repaired, or have the amp switched via the ignition this would be the cheapest option.
Regards
Mark
www.blueice-electronics.co.uk
SOURCE: tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
SOURCE: lost manual ,cant remember how to keep radio
You might be able to download for free the user manual from the Panasonic website.
SOURCE: My Warfdale 19" LCD TV
Problem will be either bad capacitors that are vented or puffed up on Top or you need to replace the main board the one you connect cable to Encompass Parts Distrbution might have it on stock
1-800-638-3328
SOURCE: how to memoriese radio channel. my jvc car radio
Hello my name is Israel. The problem is with the wiring connection. You will need to make sure that the yellow wire is connected to a positive 12 volt source at all times. What is happening is that the wire is connected to a switched 12 volt. Reconnect wire to a constant 12 volt source. Good Luck.
Testimonial: "Thanks for your help."
