Wheels are readily available on Amazon
https://www.google.com/search?q=Samsonite+spinner+mobile+office+product+code+67250+or+790224+replacement+wheels
Samsonite Luggage Wheel Replacement - iFixit
iFixit
https://www.ifixit.com > Guide > Samsonite+Luggage...
8 steps · 30 mins
1.
Clean the wheel to make sure that the wheel is not stuck.
2.
Select the right replacement by measuring the diameter and width of the wheel.
3.
Remove the screws securing the wheel clip inside the case.
How To Replace Wheels On A Samsonite 1910 Suitcase
parklandmfg.com
https://parklandmfg.com > how-to-replace-wheels-on-...
Dec 27, 2022 - Start by removing the old wheels, which can be done by unscrewing the screws that hold them in place. Once the old wheels are removed, you can ...
How To Find Genuine Replacement Parts For Your ...
https://parklandmfg.com > how-to-find-genuine-repla...
Dec 19, 2022 - Yes, you can replace the wheels on a Samsonite suitcase. There are replacement wheels available for purchase online or through a luggage store.
Samsonite Replacement Wheels - Ohio Travel Bag
Ohio Travel Bag
https://ohiotravelbag.com > branded-wheels
SOURCE: RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
SOURCE: wheel bearing replacement left front
Diagnosing the bearings can be tricky depending on severity of wear. Typically - drone noise at highway speeds, squeeling, clicking or grinding noises at low speeds that reduce during braking, or pull off the wheel and brake assembly and check the bearing for slack or smoothness of rotation by hand. While doing this, check the brake assembly thoroughly - generally a more likely culprit of wheel noise.
Wheel bearing replacement is not for the novice backyard mech. - you will need pullers, press, etc. If you can get a rebuilt assembly - much easier.
SOURCE: I pulled the codes and here they are : C0036, C0035, C0040
Sounds like you need front wheel speed sensors. Replace the wheel bearings and sensors. May have an ABS unit fault, but more likely is both wheel bearings/speed sensors.
SOURCE: HOW TO REPLACE OR REPAIR WHEEL SPEED SENSOR
It is part of the bearing hub assembly.Very have to do without air tools,If setting multiple abs/tc code (wheel speed sensors) probably abs electronic module or chaffed wires on drivers side at ac lines by air box.Have big problems with this and probably will come back.
