Dryers Logo
Beth Mitchell Posted on May 22, 2019
I need replacement knobs for my Hawaiian breeze 20 inch box fans. The knob is on the top of the fan, not the front. I have 2 of these fans and the knobs have mysteriously disappeared.
Zaccur Abdallah
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 09, 2025
Zaccur Abdallah
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
2073
Points
28
Step 1: Measure the current (missing) knob / shaft Because there is no universal knob that fits all fans, you'll need to match a few dimensions and shaft style:
  • Shaft diameter: The knob fits over the motor's speed-control shaft. Common sizes are around 6?mm, 6.5?mm, ¼" etc.
  • Shaft profile / keying: The shaft may be "D?shaped" (flat on one side), double?D, or round with a flat. Sometimes there is a slot for a set?screw.
  • Shaft length protruding above the panel: How far does the shaft stick out above the top surface of the fan?
  • Knob inside depth / bore depth: The knob's internal bore depth must match so it can fully seat.
  • Knob outer diameter / style: For grip, aesthetics, etc.
For example, I found a note in a 3D?printing forum saying:
"This knob fits the Hawaiian Breeze Box Fan. The Knobs details are: 50 mm overall diameter, total of 14 mm tall, 10 mm outer diameter for the shaft, fits a 6.12 mm switch shaft. The center switch shaft hole is 16 mm deep with the D?shape the last 6.5 mm." STL Finder That's a valuable lead: someone claims to have measured a knob specifically for a Hawaiian Breeze box fan. According to that, the shaft is ~6.12?mm with a D?shape in the last 6.5?mm. STL Finder
If you can measure your shaft (perhaps using calipers, or at least a vernier, or compare with drill bits), that will help you match a replacement.
Step 2: Look for replacement knobs / rotary control knobs Here are some knobs / parts that might work as replacements. (These are generic rotary control knobs. You'll need to check the fit.)
I couldn't find a perfect "Hawaiian Breeze 20 inch box fan knob" listing right away, but here are some knobs that might be compatible (if your measurements match):
(Note: these are examples. You'll need to verify fit before purchase.)
  • A generic rotary knob with matching bore and diameter
  • A knob for appliance / control panel with set?screw
  • 3D printed or custom printed knobs (based on the design specs above)
If you tell me your city (Nairobi? Kenya?), I can try find local suppliers or knobs available locally to minimize shipping cost.
Step 3: Alternatives / custom fabrication If you can't find an exact match, here are substitutes / fallback ideas:
  1. 3D printing a knob
    The forum I mentioned includes a 3D model for a replacement knob for "Hawaiian Breeze Box Fan" with exact dimensions. You (or a maker/3D printing service) could print one. STL Finder
  2. Use a universal knob
    Some universal knobs (control knobs) with matching bore and set?screw can work. You might have to slightly enlarge or shim the bore.
  3. Salvage from another fan or appliance
    If you have a broken / old fan or appliance whose knob's shaft bore matches, you can repurpose that.
  4. Epoxy / adhesive + knob
    As a last resort, you can glue (carefully) a knob over the shaft or fashion one out of a metal/wood knob, drilling a matching bore.
5 Related Answers
Anonymous
  • 776 Answers
  • Posted on May 31, 2009
SOURCE: interior fan control knob doesn't work
you have to remove the AC panel from the back side... the virtical console pops out and you can disconnect it (wire harness connectors) to get to it.
Anonymous
  • 83 Answers
  • Posted on Jul 06, 2009
SOURCE: Plastic knobs (off/on and fan speed) are broken. Need replacement
Only accredited service contractors carry them. You need to contact them for price and availability.
I hope this helps.
David Shaub
  • 2994 Answers
  • Posted on Oct 01, 2009
SOURCE: are replacements for the plastic control knob
Knobs for almost anything electric or electronic are available at Allied Electronics. Here's the link.
http://www.alliedelec.com/
Anonymous
  • 6771 Answers
  • Posted on Mar 21, 2011
SOURCE: My Hawaiian breeze floor fan just stopped working
One of the most common problems is the switch, bad ac cord, an open winding in the fan motor. The on/off switch and ac cord should be checked first, now! if the motor is humming but not working it is seized, the bearing is burnt, or scorched, and possibly cracked.
Anonymous
  • Posted on Jun 28, 2011
SOURCE: I just purchased a Hawaiian
The coil goes at the base of the pole stand.. You slide it up through the bottom before you attach it to the the pedestal.
Top Dryers Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
