Si al
encender la maquina, no se escucha el zumbido del motor, es que está trabado
por algún motivo, normalmente hay que reemplazar el motor poligonal, pero también
puede haberse trabado por suciedad, destapando el laser el motor queda a la
vista… este debe girar libremente si está pesado o no se mueve intente lavar
con alcohol izo propílico, si no reacciona a esto tendrá que reemplazar el
motor, el motor de la 450 puede funcionar perfectamente si los cables lo
permiten.
Digo esto
por que el de la 350 aveces cuesta conseguirlo.
If to ignite the machine, is not listened to the
humming (zumbido) of the motor, is that he is in favor joined of some reason, normaly
is necessary to replace the polygonal motor, but also the laser can be had
joined by dirt, opening the motor is at sight… this must turn freely if he is
heavy or it does not move tries to wash with alcohol izo propílic, if it does
not react to this will have to replace the motor, the motor of the 450 can work
perfectly if the cables allow it.
I say this so that the one of the 350 you
accustom hill to obtain it.
This SC code disappears when off and
on the machine does not need to reset with service programs.
This is usually to do with the scanner motor(Polygon Motor) this unit is in the laser housing..If you can hear a buzzing sound when turned on or did hear a buzz the motor masy have locked. Go into Sc code reset with yellow clear then 107 then hold down the stop button.. when the screen changes go to 5.mode and scroll down to 810 sc reset execute turn off then back on.. if the code is still there yhou may have to replace..Let me know if this helps
