My ac is not working nothing comes on I have power to the thermostat but the compressor doesn't come on and the fan won't even run I've checked the breakers and they are all ok
Must be a bad capacitor or a bad contactor.
I have some repair pictures:
OUTSIDE CONDENSER BLUES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks so much it gave me a little insite. I still have warranty so repairman was contacted.I will use your site again. thanks Heidi"
before you replace the cap and contactor, manually operate the contactor, and see if the unit runs, if it does then go to the furnace unit and check the safety float switch on the evaporator drain pipe to see if the drain is clogged, do this by gently pulling out the switch and look inside the pipe to see if water is draining, if not take the pipe off and shoot some compressed air in the pipe to clear it then pour in a small amount of bleach into the pipe after you have reassembled it, Make sure the unit is off so the bleach doesn't shoot back up on you. then turn the unit back on and wait five minute to see if that worked.
