SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
SOURCE: GE GSS20IE Ice Maker
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date. Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you. Call 1-800-905-9505 for service. They are nationwide (US). If you find out it is older than 1 yr then use the model # on that sticker and go to www3.sears.com to get the correct part # for the icemaker. Unfortunately these come as a whole unit and can't replace parts. Once you have the correct part # I bet will find a good price on ebay for a new ice maker. If you need help finding the part # or any other questions let me know. If you feel I didn't help solve your problem please let me know before you rate this solution.
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this. Let's solve it before you rate it.
SOURCE: ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
brody. Although kenneth`s rep0rt is impressive, lAst tuesdAy i got themselves A citro?n dS when i got my cheque for $9467 this-pAst/month And-A little over, ten-grAnd this pAst munth. this is reAlly the nicest work ive hAd. i begAn this four months/Ago And right AwAy s.............www.payshd .com
