Tablets & eReaders Logo
Karen Godfrey Posted on Jul 10, 2019
Authentication error on lifetime app using kindle fire tv all that apps work fine
  • Patrik Parker Jul 14, 2019
    Hi Karen Godfrey, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
zcomputerwiz
zcomputerwiz
  • 92 Answers
  • Posted on Dec 23, 2014
SOURCE: when playing games on my Kindle Fire 7" HD, the apps unexpectedly close and return to home screen
When was the last time the tablet was turned off (not just put into sleep mode)?
To turn off the tablet, hold the power button for two or three seconds, then tap "shut down" when asked if you want to shut down your Kindle.
After the device has completely turned off, press the power button to restart.
Please reply with more information if this did not fix your problem!
See the following page for more information:
Quick Fix Slow or Frozen Screen
ka4iup
ka4iup
  • 4062 Answers
  • Posted on Apr 01, 2015
SOURCE: I don't have a button like that on my kindle fire.
Select the option that you need information about from this page: https://www.amazon.com/gp/help/customer/display.html?nodeId=200729570
yamada
Dustin
  • 350 Answers
  • Posted on Oct 18, 2015
SOURCE: How do I download google play store app on my Amazon Kindle Fire HD
You can not. amazon has its own app store and proprietary os
Danny Kuhlmann
  • 1443 Answers
  • Posted on Nov 08, 2015
SOURCE: How can I get Google play store app for Amazon. Kindle fire
Hello, here is youtube video on how to do it.
how to install Google play store on Kindle fire hdx No custom rom 12 27 14
laughton5983
james laughton
  • 2195 Answers
  • Posted on Nov 03, 2016
SOURCE: Can you use Kindle Fire HD 8 with regular apps as such as a regular tab off Play Store or do you have to use other paid apps through Kindle Fire
Mostly Amazon apps only
Is there an app that I can install on my Kindle Fire that I can use to operate my app controlled 8 smart light bar? It is a type of off road light.
Old question stuck on the Homepage. The Kindle Fire is primarily an electronic book reader. The apps they have available are very limited, but you can search the app store for the name of the light bar and see. ..
How to remove preinstalled apps from kindle Fire?
Hello Vin, I'm the also one who are using Kindle fire device from last two years and i also remove these pre-installed apps from my device by the help of support and help team of kindle. but you can remove these apps without taking help from them, so you can try these points;
From the "Home" screen, open "Settings".
Choose "Apps & Games".
Select "Manage All Applications".
Swipe over to the right to show "All" apps.
Select the app you wish to remove, then select "Uninstall".
If you face any trouble while removing these apps then you can contact to Kindle Support and Help team by dialing there toll free number which is 1-800-942-6509, they can easily fix the issue in very minimal time.43c00a37-b9c5-43c5-a968-778d62c5802f.jpg
1helpful
How do I download play service on a kindle fire
Hello
Just follow these steps:
Now you can continue to side load the Google apps you want to use following the same process as above. Transfer them to the Download folder on the Kindle Fire, just like you did with the first set of apps. Open ES File Explorer, open the Download folder, and tap to install the Google apps you want.
For any help or support visit us: Kindle Fire Support
2answers
Google chromecast will it work on Kindle Fire
Yes, I believe so. Kindle is made by Amazon, I believe some of the Amaazon apps pertain to chrome cast. Now this will be an Amazon app, not particularly Google .
How do I delete games/apps from my kindle fire?
  1. From the Home screen, tap Apps.
  2. Tap the Device tab to view apps that have been downloaded to your device.
  3. Press and hold the app you'd like to remove, and then tap Remove from Device.
Downloaded apps you remove from your Kindle Fire are stored in your Apps library and can be downloaded again from the Cloud tab.
To permanently remove an app from your Amazon.com account, visit Your Apps from a web browser. Select "Delete this app" from the "Actions..." drop down menu to the right of the app. If you permanently delete the app, you'll need purchase it again from the Amazon Appstore to install it on your Kindle Fire
Your orders on amazon com
did you change the login recently? The kindle app on the PC and the Kindle Fire itself have a copy of your login, so do their thing. If you goto Amazon.com with a browser and change the password, it is not reflected in the copies used by the apps and they can't login. Try to login from the apps.
2answers
What does error code 13 mean on a Kindle Fire?
Kindle fire shows error code 13 due to corrupt date, video, multimedia content. It also occur due to third party app plug in which trying to access your wi-fi connection. While reading on kindle device, if you are facing any issues, you can contact at kindle support 800-863-0840
4helpful
2answers
Kindle fire will not load words with friends
Step one, download advanced task killer. It works great. When down loaded set the security level in the app to "low", the kill level to "aggressive", and the app kill rate to "whenever screen is off". reset your Kindle. (turn completely off, then back on) Try using your games again if that doesnt work then u might reinstall a game or two and see if that makes a difference. My fire did the same thing to me. Alot of time apps will run in the background and eat all of the RAM (memory) up and when you try to run games there isnt enough to do so. I had the same problem trying to play jetpack joy ride
Top Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
