Hi do you know the sky remote code for a bush tv? idlcd37tv16hd
For Bush 32 inch LCD TV, after many codes tried finally, 1239 is the code that works. Richard in Ireland
I need the model number for my Bush tv, but i cant due to it not having the uptodate tv i have, would anyone be able to help me sort it out.
Hi Trebor25, well I have had the exact same problem with my Bush TV and last night finally cracked the problem and found the code for my Sky HD remote, I guess it will work with all sky remotes too?
Being as Argos, Bush (AKA Alba) and other commercial companies were most unhelpful, sky just gave me another 1000 codes to try and spend another 24 hours typing codes into their remotes? I want to restrict acccess to the code number to find out how many bought and have problems with this TV and and their sky remote, no names or details just numbers recorded. If you would like to the code you can drop me an e-mail to chris.dixon6901 at googlemail dot com, just use the TV Type as the subject "BUSH IDLCD37TV16HD" so I know who to answer.
No commerical companies please, I spent the last 10 months typing in codes to get this number which is not a standard Bush code or a normal manufacturer of their hardware.
Codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Use the matsui code 0477. some of the BUSH badges TVs are actually made by matsui. this worked for Bush LCD32TV30HD
I HAVE THE BUSH IDLCD37TV16HD AND HAVE TRIED HUNDREDS OF CODES OFF ALL THE WEB PAGES WITH NO LUCK, ANYONE FOUND THE RIGHTCODE YET ??
Hi thanks for all your help. i have now got my remote working but from day one i have had to do the volume from the normal tv remote. any one got the answer to why ! i have called sky they said they have that problem a lot with my kind of tv and i should be able to find on the internet. any help anyone !
thanks martin
can someone please give me the sky remote code for IDLCD37TV16HD
hi need remote code for a. umc m40/57g-gb ftcu- uk
