When they are plugged in they work along with the tablet. Volume coming from both areas.
SOURCE: How do I get speakers working on 7.85 tablet?
Check the volume control, if the volume is up, then verify that the headphones work OK by testing them on another device.
You may need to power off/power on the device and try again.
Every thing is low quality chines junk these days and probably head phone jack input is broken and it is not repairable as all similar items ,
As mentioned above, SoundAbout should work.
"No sound on external speaker" problem is often caused by:
- damaged speaker,
- damaged headphone jack,
- damaged audio codec (hardware).
You can try to ask your problem here: https://www.elvikom.pl
There are many service technicians with high-level experience, which may help you to repair your tablet.
You can try spraying a very small amount of electronic contact cleaner in the port and work the connector a few times in and out, if this doesn't work you have a bad connection with in the phone.....
Hi Mike Trexler, I want to help you with your question, but I need more information from you.
Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7/
