Refrigerators Logo
David Cropper Posted on Aug 17, 2019
I installed a new thermostat in my true cooler but it just runs all the time never shuts down?
5 Related Answers
Anonymous
  • 1420 Answers
  • Posted on Nov 26, 2007
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Anonymous
  • Posted on Jun 26, 2008
SOURCE: Wine cooler
Thermostat again.
Anonymous
  • 101 Answers
  • Posted on Oct 02, 2009
SOURCE: Furnace and Air conditioner run at the same time
Odds are u did just that or wrong thermostat,If u don't have a digrahm get one from Library.
Anonymous
  • 43501 Answers
  • Posted on May 28, 2010
SOURCE: walk in cooler cycleing
It has lost some freon and is not charged correctly...the unit is pumping down and shutting off on low pressure and then after being off a bit the pressure comes up and it restarts...
Need to check the charge and top it off and you will be good to go..
heatman101
Testimonial: "Thanx for the good advice."
duane_wong
Duane Wong
  • 6827 Answers
  • Posted on Jul 12, 2010
SOURCE: My true cooler gdm-45 is
The thermostat seems to be bad. Or, the defrost timer is staying on too long.
Top True Refrigerators Experts
jdthefixer
Narseman
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a True Refrigerator Expert? Answer questions, earn points and help others
