Dell XPS M1530 Laptop Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery charging for few seconds before it stops
When I plug in the battery it shows charging for few seconds and then it stops and does not take any charge.
  • Anonymous May 11, 2010
    There are a few explanations: 1. Faulty power adapter 2. Faulty battery 3. Faulty power jack (connector in laptop) Test the power adapter without the battery to see if the battery is faulty. If no change, the power adapter could be faulty. If you have another laptop to test, you can determine if the power adapter is faulty. Wiggle the power cable a bit, if the charge is longer, then you could have a faulty power jack. The power jack may need to be replaced or resoldered. Hope this helps.
Anonymous
Level 3:
  • Master 558 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
Answers
558
Questions
0
Helped
198403
Points
1466
You will have to replace the battery.If you are still under warranty.Worst case the motherboard,but i think the battery is bad.I Hhav the same problem with a inspiron 1525
Good luck
Anonymous
Level 3:
Genius:
  • Master 1,043 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1043
Questions
Helped
289426
Points
3188
Either the electronics in the charger or the battery have failed. If you still have any warranty left on the laptop call Dell support and they will assist you in identifying which one has failed.
1 Related Answer
Anonymous
  • 2567 Answers
  • Posted on Sep 15, 2010
SOURCE: hey hi this is nammy........my acer 4736z battery
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
