Yesterday I drove my buggy from the club trolley shed to the putting green, about 80yds. All okay. When I got back on my buggy it went about 25 yards all ok. I then got back on my buggy it went about 12 inches and stopped abruptly! I kept using the accelerator and sometimes I went 2 yard and stopped, but mainly it was about 12 inches. I then drove it back to the trolley shed, but I was hardly turning the accelerator. I was going about 2 mph, if I tried to go faster it stopped. The two batteries are fully charged, the indicator light was showing fully charged, Do you think there is a fault in the accelerator? someone suggested I need a solenoid??? What's that? Any advice please?
Check your motor brushes..battery and these are common faults..do you carry to course in car and break down ..it might be wiring fault also
Question edited for clarity.
Question moved to golf.
Solenoid. (electro-magnetically operated switch)
What are the symptoms of a bad solenoid in a golf cart?
On an electric golf cart, the most common symptom is the solenoid is not delivering electricity to the controller when the vehicle's ignition is turned on. In normal operating conditions, the solenoid clicks on and off with the ignition switch. A failing solenoid will generally not click.
https://www.google.com/search?q=patterson+golf+buggy+solenoid
If it clicks, it is more likely to be the accelerator potentiometer, basically the variable gas pedal. Great resource in the link for Golf Cart woes.
https://www.golfcartsforsale.com/blog/5-common-electric-golf-cart-problems-solve/
