Kitchen Ranges Logo
E
Earl Morris Posted on Sep 22, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Temperature keeps dropping and takes too long to heat back up ,constantly and taking product longer to cook
R SHOAIB
Level 3:
Master:
  • Master 567 Answers
  • Posted on Feb 23, 2023
R SHOAIB
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
91548
Points
1019
If your oven temperature keeps dropping and takes too long to heat back up, it could indicate a problem with your oven's heating system. Here are a few things you can check:
  1. Check the oven's heating elements: If one of the heating elements in your oven is faulty, it may cause the oven temperature to drop. Turn off the oven, unplug it, and visually inspect the heating elements. If you see any signs of damage, such as cracks or breaks, the element may need to be replaced.
  2. Check the oven's thermostat: A faulty thermostat can also cause your oven to drop in temperature. You can use an oven thermometer to test the accuracy of your oven's thermostat. Simply place the thermometer inside the oven, set the oven to a specific temperature, and wait for it to heat up. Check the thermometer to see if it matches the oven's temperature setting. If it doesn't, the thermostat may need to be replaced.
  3. Check the oven's door seal: A damaged or worn door seal can cause heat to escape from the oven, which can result in a drop in temperature. Inspect the door seal for any cracks, breaks, or other damage. If you notice any issues, replace the seal.
  4. Check the oven's control board: If the above steps do not resolve the issue, it could be a problem with the oven's control board. Consult a professional technician to diagnose and repair the issue.
Top Kitchen Ranges Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
