This manual said leakage of electricity or power supply, and not to use it on Page 13. I do not have any personal knowledge of this device, but that sentence in manual is alarming to me.
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
I am trying to print via wi-fi direct, and it gives me:
SPL ERROR -Please use the proper driver
POSITION 0x0
SYSTEM h6fwasim/x1_image
LINE 398
VERSION SPL 5.73.04 06-10-2014
ERROR CODE 11-1113
With the MSPA this is a code that has something to do with the wire coming from the panel to the control boxCheck the pins to make sure they are not bent and are plugging in correctly. RodUS Parts Center
