Frigidaire Affinity ATF7000E Front Load Washer Logo
Anonymous Posted on Oct 07, 2009
E68 error code. What steps do I take to fix it?
1 Related Answer
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Aug 17, 2011
SOURCE: Was receiving E68 code on
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Need help my affinity dryer has the code E68 on it and the code Dr the model number is LGQ7000ES0
E68 is a stuck button error code... There is a diagnostic video for this on YouTube. You will have to get a new control board to fix the problem because the buttons are part of the board... Frigidaire Dryer Main Control Board 134557200
Jun 08, 2016 • Dryers
E68 error code
Hello Friend, this is Z. Thank you for your post!
Typically error code E68 indicates a current leakage to ground on heater or an open fuse. Normally, an experienced technician would check the resistance of the heating element. If it is normal, their next step would be to check the resistance between the ground and both heater terminals. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your washer is experiencing. Best!
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
Fix E68 error code on xbox360 slim
Hi there elaine try this walk though i have put the link in here for you to to step by step instructions it sounds like the hard drive is gone..
http://www.wikihow.com/Fix-an-Xbox-360-Error-E68
Cheers Nikki
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Cause:
Disengage button.
What causes error code e68 on x box n how can it be fixed?
e68 is your hard drive , you could try formatting it, but it might be an error with the interface on the xbox itself
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
2answers
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
1helpful
How do i fix an e68 fridgidaire problem on an affinity model
A key is stuck as indicated by the error code E68; enter the service diagnostic mode and perform the key test to determine which key is stuck. Unstuck the key then perform the key test again. The electronic control board (part number 134557201) needs to be replaced if the error code continues to appear. Click here for the diagnostic and key test procedure.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
