Microsoft Xbox 360 Console Logo
Posted on Oct 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have code error 74 - Microsoft Xbox 360 Console
Anonymous
Level 3:
Genius:
  • Master 1,093 Answers
  • Posted on Oct 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1093
Questions
0
Helped
149051
Points
2211
Code E74 1 red light flashing and error message on screen right? It is the scaler chip, it happens because the scaler chip starts overheating. If you stop the heat build up on the chips then you should be fine.
You can send your Xbox 360 back in for repair or fix it yourself with a good Xbox 360 Repair guide
1 red light e 74 code
E74 is an error related to video. It's either:
  • Bad video cable
  • Bad graphic chipset issue
Try a different video cable, unplug and plug it back in to make sure the video cable is seated properly. If it's neither of these issues, the only thing to do is to contact Microsoft's customer service and get it replaced/fixed.
1helpful
My 360 received an error code 74 what does this mean and how can i fix the problem without sending my 360 in for repair
4TH LIGHT ON ERROR CODE 74 SYNC CODE 1022
Things DONE;
replaced AV cable
cleaned contacts
WHAT NOW !
1helpful
Sudden toner outage
yes, error 74 points to toner empty. open front door, press "options" then "start" then "1" and "0". once shows accepted, close front door. make note of this as it very well may happen again.
hth,
razors
5helpful
2answers
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Error74
http://forums.planetxbox360.com/xbox-360-hardware-discussions/17416-1-ring-error-code-74-help.html
Scalar chip or faulty video cable
2helpful
1987 s10 pickup Service engine
Slow down, don't start tearing down the engine just yet. Error 74 is: P0074 Ambient Air Temperature Sensor Circuit Intermittent.
http://www.engine-light-help.com/generic-check-engine-light-codes.html
1helpful
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Console
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
3answers
Error 74
error code 74 is
Maxicube
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
