E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Sharp AR-5132 won't print
Error code E7 13
It will warm up like it's about to print or scan then error code E7 13
please give any advice
Whats the LSU
i have AR5316 code shows E7-16 what can i do to solve this problem?
i have the problem it show me the code E7-11 i saw ur answer but i dont know what do u mean by (White Correction)
can u plz help me to understand what do u mean by that
thnx for ur help
hi
i have the E7-11 problems in the sharp 407 but i dont know what do u mean by the White Correction and i dont know hoe to solve this problem
can any one plz help me to solve it
thnx to all
what is H4 and how do i clear it of from my copier
