Little Tikes Totsports Easy Score Basketball Set Logo
Posted on Dec 12, 2009
How do i string the net - Little Tikes Totsports Easy Score Basketball Set
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
13764
Points
39
Http://www.littletikes.com/pdf/4612 10_98.pdf
this is the manual for your item.
To lace the net, take top of each loop, slide it up thru each center hole and spead it over the two end pins.
See pics # 10 & #11
eNJOY AND HAVE A HAPPY HOLIDAY
  • jbrianj Sep 18, 2010
    Alright, after doing it the way the manual recommended. I finally added a step.
    Push the Net through the hole first.
    Then I threaded some twine through the loop of net that was sticking through the hole.
    Bring the twine through the slots on either side of the hole then tie the twine tightly behind the net.
    I trimmed the twine to keep things looking neat.
    Net isn't coming off now.
1helpful
The door falls
On on both (L&R) outside wall are strings and springs. The strings can break where they go over the pulley. You have to pull the unit out of the counter. May be screws on side or top to remove + kill the power to the unit. Then slide out about 3/4 way (first take bottom foot panel off and watch wires and hoses for clearance when sliding). Note the strings that are broken and look on net for new strings.
How to load string
See pages 10 and 11 of this manual for string loading instructions and diagrams. You will need Adobe Reader installed on your computer to view this. If you don't have it, it is a free, safe download for the program.
http://dl.owneriq.net/b/b47485ac-caaa-7214-2505-a3cc6b214a7a.pdf
What type of string do I buy for my homelike weed eater
Without knowing your model number, the typical string for the Homelite trimmers is .080" string.These types of units use that:
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
I'm from Washington state. I bought a damaged 4-string Sitar/Tanpura ? It needs repair work. where can I find this service? Thank You Judy kayak1950@comcast.net
Look up Luthiers in your phone book. There are a couple in Seattle.. one on Capitol hill.
Normally a Sitar has seven strings plus some sympathetic strings underneath... the word Sitar means Seven.
Feb 09, 2011 • Music
Create a program that asks for a sentence. Your program will then check if the sentence is a palindrome or not.
Palindrome using C#.net
using System;
using System.Collections.Generic;
using System.Text;
namespace ConsoleApplication1
class Program
static void Main(string[] args)
string str=string .Empty ;
Console.WriteLine("Enter a String");
string s = Console.ReadLine();
int i = s.Length;
//we can get the Length of string by using Length Property
for (int j=i -1; j >= 0; j--)
str = str + s[j ];
if (str == s)
Console.WriteLine(s + " is palindrome");
else
Console.WriteLine(s + " is not a palindeome");
Console.WriteLine(str);
Console.Read();
Not able to remove a software
Error Number: 0x80040703
Description:Failed to find dll function: SAM.AddProperty
I am able to load the dll but not call the methods.
The method that is being called from my c++.NET dll is:
void AddProperty(String *name, String *value) throw(...);
Below is my install script:
prototype SAM.AddProperty(POINTER,POINTER);
nResult = UseDLL(SUPPORTDIR ^ "SAM.dll");
STRING sKey;
STRING sValue;
POINTER psKey;
POINTER psValue;
sKey="Key";
sValue="Value";
psKey = &sKey;
psValue=&sValue;
AddProperty(psKey, psValue);
I also tried sending in STRINGS instead of POINTER but that didn't work either.
prototype SAM.AddProperty(STRING,STRING);
STRING sKey;
STRING sValue;
sKey="Key";
sValue="Value";
AddProperty(sKey, sValue);
MS Access and ASP.net application
You probably need to be inserting the value of a text object (ie, a String) , not the object itself. In VB.NET, a String object is an actual, not unlike a Java String object. In "classic" VB, a String object isn't really handled by the interpreter as an object in the C# / Java sense, so it can be referred to directly without resolving the value via a method call. So attempting to insert an object reference into a database field from C# code will probably not work unless the database knows to call toSting() on the object, which I am 99.99999% sure it cannot (depends on the database-- in this case Access, and more particularly, what version you are using, and if there is any .NET framework interoperability).
Calling myString.toString() though returns a String object in C#, so using that is likely not going to work. What you may need to do is return a character array using the 'chars' and 'length' properties of the C# String object.
Finally, after all this, your problem could be a lot simpler: the value(s) you are trying to insert may not be right for the field-- check the length of the values being inserted, etc. Use .trim() to eliminate leading and trailing whitespace, for example. If you post your INSERT statement and an example of the data you are using, I may be able to tell you more. Also, you are in ASP.NET and data transfer from web containers to Access databases is notoriously bedeviled work.
Top Little Tikes Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
