Sharp AR-5320 Black and White Copier Logo
Anonymous Posted on Jan 22, 2008
Error code hi i have a problem with sharp AR-5320 copier. H and 4 are blinking can you help me please
Andy Bebb
Level 2:
  • Expert 62 Answers
  • Posted on Jan 22, 2008
Andy Bebb
Expert
Level 2:
Answers
62
Questions
0
Helped
29554
Points
110
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
  • Anonymous Dec 26, 2011
    Error gone..................... Thank you very much.....
  • Anonymous Apr 04, 2017
    Thank you so much.. I tried it too and it worked. I was so scared I had broken the office copier.
A
Anonymous
Thanks it is working now
2 Related Answers
Anonymous
  • 372 Answers
  • Posted on Sep 19, 2011
SOURCE: My AR-5320 Sharp Copier is
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Anonymous
  • 44 Answers
  • Posted on Sep 30, 2011
SOURCE: my sharp ar-5320 copier has an error code blinking
The H4 stands for a problem in the heater circuit for the fusing unit, It could be a thermo fuse, thermostat, thermistor, bad heat lamp or worn fuser rollers. The H4 will not reset until either of these components is repaired or replaced. Hope this helps.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
