Element Electronics ELCHW261 26 in. TV Logo
Anonymous Posted on Dec 23, 2009
Need code to program suddenlink remote to operate my Element ELCHW321 model HDTV
  • Anonymous Aug 05, 2010
    The Code for this TV is 0178 I actually posted this ? originally in Dec. of last yr. That same day I found the code that worked and forgot to list it for others since then my suddenlik equipment had to be replaced and yes I forgot to write down the code and finally afters hours of searching I finally found it So this code dose work the only one I found for Element TV's that dose all fuctions again its 0178. Hope this helps
    the code is 0178
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Sep 17, 2008
SOURCE: need code for remote control
0054, 0030, 0171 are the only codes available for sylvania tvs with your remote
Anonymous
  • 170 Answers
  • Posted on Mar 17, 2009
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Anonymous
  • Posted on May 14, 2009
SOURCE: need remote code for LG HDTV model 47LG90...
Just bought an LG 32" HDTV and have the new Samsung STB, with a Scientific Remote; the code in the remote manual for LG says to use 1005, but after trying it and many others, I used the "Find Code" set-up (991) and (990) in the remote manual and happened upon 1004 for the LG.
While this worked, the remote is a bit awkward, as you have to enter yet another code (998) in order to control the Power for both the TV and Box with the remote; the good news is that the instructions to do this are pretty straightforward and well presented.
Now, I can turn both TV and Box on/off with power button on remote, can change channels with remote and also vary volume with remote!
Hope this helps
Anonymous
  • Posted on Jun 01, 2009
SOURCE: Suddenlink remote will not operate my Olevia LCD TV
Device Key Code TV. 1610
  1. Turn on a device and, if applicable, insert video media, (e.g., cassette or disc).
  2. On the remote control, press a device key once (i.e., VCR, DVD, AUD, TV, or CBL); it will blink once. Then press and hold SETUP until the selected mode key blinks twice.
  3. Use the lookup tool below to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice.
    NOTE: If the selected mode key emits a long blink, the entry is invalid. Repeat steps 2 through 3 and try entering the same code again.
  4. Aim the remote control at the device and press PWR once. The device should turn off. If it does not, repeat steps 2 through 3, trying each code for your brand until you find one that works. If it still does not respond, try searching for the code (see “Searching for Your Code”).
    NOTE: If the device does not have a PWR key, press the PLAY key.
  5. Repeat steps 1 through 4 for each device you want the remote control to operate. For future reference, write down each working device code in the boxes on the following page.
Anonymous
  • 55 Answers
  • Posted on Oct 08, 2010
SOURCE: need to program suddenlink remote
You May Try ProView Codes and they are Manufactured in the Same Factory in China
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
