Kenmore Elite 45986 Front Load Washer Logo
Posted on Jan 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HE4t Elite F02 error code
Can you tell me what the F02 error code means?
  • 5 more comments
  • Anonymous Jul 01, 2008
    where is the drain pump filter?
  • stang713 Feb 01, 2009
    Fo2 error says drain problem but I've cleaned all hoses and the error still exists-what do I do???
  • gdocharlotte Feb 23, 2009
    washer will drain and spin with nothing in it, but as soon as I put towels in which are still wet from it not draining correctly, the FO2 message appears?
  • lady mic Feb 25, 2009
    my f02 keeps coming up at the 2 min mark. I snaked the drain, cleaned the hose and put vinegar in the machine to clean it. it still keeps flashing. now it won't drain the water. it use to drain it after reseting it 3 times now it won't. help.
  • RONDA PERRY Mar 19, 2009
    I'M GETTING A ERROR CODE OF F02 AND SUD WHAT DOES THIS MEANS
  • Anonymous Mar 21, 2009
    same problem f2 error code he t4 2006 front load washer from sears; i think he drain pump is clogged for some theory not sure why but remener the tech last visit said if suds come uop as code its getting bocked but the control pabel locked and not do damn thing to unlo9ck; need control sheet error code list and how to solve issues on own daniel440@verizon.net
  • Anonymous Aug 26, 2012
    great advice, right one spot - thanks!
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Jan 25, 2008
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
908999
Points
3823
Its the error code for a long drain time most likely you need to check the filter in your pump for obstructions First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
  • 6 more comments
  • Mark Olson Oct 31, 2010
    Good answer. Good technique. Good on the details. Thanks!
  • crprater Dec 09, 2010
    Did as you suggested!!! WORKED! Thanks!!!!
  • DIYwarrior Jan 19, 2011
    tech 17... what kind of washing machine witchcraft do you possess? we also found a sock and several items that we shipped to the CDC for analysis. THANK YOU!!!
  • kconvy Mar 30, 2011
    AWESOME, it's 2011 and his technique still worked perfectly! I found two kid socks and one infant mitten, a penny, and 8 BB's stuck in the little holes! No wonder it couldn't drain!!! Love this washer as I bought it in 2005 and this is my first fix! Thanks tech17, you will always be relevant!
  • Anonymous May 29, 2012
    Very helpful. 1 sock, a wristwatch and loose change.
    Gread advice, you were right on spot - thanks!
  • Scott Kuntz
    Scott Kuntz May 12, 2014
    Thank you very much, 1 sock, 2 pennies and a spent bullet case. very detailed step by step instructions
  • DJ Laura
    DJ Laura Jun 21, 2014
    Don't mean to sound like a dumb girl, but where are the screws from the lower panel at the front of the washer located? I can feel what might be two screws on the underside of the front panel, but don't want to just start pulling stuff off in case it's the wrong thing!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13245
Points
I did exactly what tech17 recommended and it worked like a charm. I had a shop vac so that definitely helped with the draining process. After I unscrewed the filter, low and behold, my child's small sock was plugging the valve. Now to see it how it go there.
  • fred zinda Oct 08, 2011
    my plug was further up where the large black hose hooks onto the bottom of the tub. I removed it by taking the back off the washer and then removing the clamp on the drain hose. I found a lot of material clogging it up. I dug it out with a bent wire.
Anonymous
Level 3:
  • Master 770 Answers
Anonymous
Master
Level 3:
Answers
770
Questions
Helped
481507
Points
1794
F/02= Long Drain > If the drain time exceeds 8 min the water valvles are turned off and F/02 is flashed Press pause/cancel twice to clear
Note: After 4 min th eSUD Error will be displayed then 4min later the F/02 error code will be displayed
This is usally caused by using too much soap
Mukesh Kumar
Level 3:
  • Master 3,230 Answers
  • Posted on Aug 28, 2009
Mukesh Kumar
Master
Level 3:
Answers
3230
Questions
0
Helped
913399
Points
9208
I suspected suds build up, so I tried both regular wash cycles (e.g. Normal) and Rinse and Drain cycles multiple times to clear suds in the system, but still received the F02 error. Sometimes the SUD error message came up, but not consistently.
I ran the built-in Diagnostics tests. It made it to C:06 then got stuck.
In both scenarios above, the washing machine continued to try to pump water out, despite the fact that all the water had already been drained. After 8 or so minutes, the F02 error came on. As I understand it, if the pressure switch detects either water or suds, it commands the drain pump to continue. After 8 or so minutes, if it's still detecting water or suds, the F02 error is displayed.
I performed the following with no success:
1. Check Wire Harness connections - OK
2. Check Drain pump. – OK, as water drains at a rapid rate
3. Check Drain pump motor - OK, as water drains at a rapid rate
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects. – OK, ran a cable through both hose assemblies (exterior and interior) and not blocked.
5. Check the CCU – appears to function normally.
6. There were no kinks in the hoses, nor was the height of the pump beyond what the manual recommends.
After more diagnostics and troubleshooting, I found that the Pressure Switch was stuck and reported the SUDS state (continuity made between contacts 11 and 14 on the Pressure Switch itself). I ran many Rinse and Normal cycles with no detergent and still got this F02 error. I checked the state of the Pressure Switch’s Empty and Level 1 contacts which intermittently reported the correct water level condition (EMPTY and Level 1). In all cases contacts 11 and 14 (SUDS) were continuously made (connected) irrespective of water level, rinse conditions and the use of no detergent.
I removed the pressure switch and tested it by blowing into the inlet and did hear the switch click, so it seemed to work properly. Given the diagnostics above, I concluded that the pressure switch hose must have been clogged.
Good Luck!!
Anonymous
Level 1:
New Friend:
  • Posted on Jul 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13245
Points
I'm sure this would have worked if either I owned a huge horse-powered wet/dry vacuum or didn't have a filter clogged with close to 1 cup of ****. That being the case, the instructions got me in the direction of understanding that my filter was indeed so clogged that I couldn't evacuate the water with my wimpy vacuum and got me into the MacGyver realm. I wound up removing the access panel under the door and using a T-20 (TORX) head bit w/ driver removed the filter/pump unit from the base of the washer (keeping the hoses connected). As a side note, if you don't have TORX bits, a 7/64" hex head wrench/bit will work too. I then fashioned a trough by cutting a 24 oz plastic party cup in half length wise and duct taping it to the underside of the filter housing. After placing a 3 gallon cleaning bucket under the trough, I slowly unscrewed the filter housing cap and allowed the water and some of the "gunk" to drain into the bucket. Not as clean as using a vacuum to **** the water out of attached hoses, but it worked.
Anonymous
Level 1:
  • Posted on Aug 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13245
Points
Tech17: Fantastic solution (#2)! Not sure how/where to have used the auto hose clamps, but it certainly did the trick to get that errant sock out of the filter bed. Many thanks...
Anonymous
Level 1:
New Friend:
  • Posted on Aug 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13245
Points
I couldn't see Tech17's solution, but all your "this and that worked" replies got my washing machine fixed...Thanks
Anonymous
Level 1:
New Friend:
  • Posted on Jun 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13245
Points
I pulled my discharge pump and found a broken impeller shaft. Does anybody know where I can get this part...
John
Anonymous
Level 1:
New Friend:
  • Posted on Apr 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13245
Points
The Tech 17 solution below still works!!! I found 2 kids socks, a screw, part of a crayon and some foil...thanks, and here are your 4 boxes...
  • Anonymous Apr 19, 2010
    Tech 17 solution still works. I found 2 kids socks, a screw, part of a crayon and what looks to be like foil...thanks again tech 17, and here are your 4 boxes....
  • Anonymous Oct 16, 2010
    So funny, as I found the same thing in my washer. 2 kids socks. How do those things get there?
bonielster
Level 1:
  • Posted on Apr 13, 2008
bonielster
Contributor
Level 1:
Answers
Questions
0
Helped
13245
Points
DId the job. Saved me a ton in not having to have a tech come out. Follow the directions exact with the shop vac and you will be in fine shape!!!!!!!!!!!!!!!!!!!!!!!
Shayne Kardal
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on May 05, 2017
Shayne Kardal
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
13245
Points
With the back and top off, you will see the pressure switch (back right top). Attached to that is a small black hose. Follow it down to the drum and you will see a white assembly (air Trap) that attaches to the drum. With a flash light you can observe how much guck is in the white assembly, if this is clogged you will have to remove a small screw holding it on, remove the wires and unlatch clip near back. Have small container to catch water as you remove assembly. Once off use a bottle brush or tooth brush to clean out! This guck stops Vacuum from working due to slow drain and poor suction and produces F02 error.
http://cdn-d.appliancepartspros.com/0029391543_4.gif
14 on the diagram is the Air Trap
Sarah VandenBerghe
Level 1:
New Friend:
  • Posted on Mar 15, 2015
Sarah VandenBerghe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13245
Points
25
So how can I tell if the pump is working. We took it apart and did find a few items but still get the error message so we are thinking we need to replace the pump.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 29, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13245
Points
Yes! pulled out two small socks and some other disgusting stuff. Save me a service call. Shopvac worked great also. Make sure you pull the wet clothes out of washer and shopvac the water in the washer for best results and no flooding. Thanks again.
Anonymous
Level 1:
  • Posted on Sep 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13245
Points
Tech17 is THE MAN! The only thing I didn't do was grab the shop vac, but had plenty of towels on hand. I found:
  • 2 socks
  • A cat worth of hair
  • About 3 bucks in change
  • A screw
  • A rivet from some jeans
  • And a Bead from who knows what?
Thanks, you probably just saved me a couple hundred bucks!
Anonymous
Level 1:
  • Posted on Jun 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
13245
Points
Anonymous
Level 1:
  • Posted on Feb 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13245
Points
TECH 17 thanks for the info, problem solved . FOUND A SOCK TOO, 2 DIMES AND RUG FIBERS THANK YOU!
Anonymous
Level 1:
  • Posted on Feb 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13245
Points
RIGHT ON! I opened the front panel & found a sock, all the backing crumbs of my rug, a shell & a penny. I am soo thankful!
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
