Anonymous Posted on Dec 28, 2009
How do I insert the = sign into an equation - Office Equipment & Supplies
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on Dec 31, 2009
k24674
Level 3:
Answers
8093
Questions
0
Helped
4761499
Points
21601
I checked your problems.
  1. There are three questions asked by you. The first one concerns how to insert the = sign to create an algebraic equation. It was answered correctly by someone.
  2. The second one also concerning the = is still awaiting a solution. But it was filed under Copiers.
  3. The third question (this very one) is no question at all since you claim the site is sending you in circles.
Here is the solution to your two questions.
To insert an equal sign in an equation on the Casio FX-115ES one uses the key combination [ALPHA][CALC] (=).
To insert other variables (A,B,C,D,X,Y) you do as follows
[ALPHA][(-)] (A).
[ALPHA][' " "] (B).
[ALPHA][hyp] (C).
[ALPHA][sin] (D).
[ALPHA][ ) ] (X).
[ALPHA][S<=>D] (Y).
The only other uses of the [ALPHA] key are
[ALPHA][Integral] (:)
[ALPHA][M+] (M) to access constant memory register
[ALPHA][x10^x] (e) to access value of the base of the natural logarithm.
1helpful
Where is the division key on the keyboard
You can either use the slash key / or if you are using Word you can insert am equation
At the top of Word click the insert button, third from the left.
Then on the far right click insert equation. There you have an option to put in almost any mathematical symbol. You could use either the division or fraction sign.
What is an antonym for equation
There are various ways that a mathematical expression fails to be an equation. It lacks a relational operator (symbol). It has a less than sign, or a greater than sign, or a combination of other symbols. If you language homework requires(?) that you find an antonym for equation, try non-equation.
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
What does the equation mean a^2 b^2 = c^2?
With the insertion of a plus sign it's "a squared plus b squared is equal to c squared." Applied to the Pythagorean Theorem it's "the sum of the squares of the sides is equal to the square of the hypotenuse."
How do I type an equal sign into the calculator? As in 5x+6=6x-3. I want to put this equation into the calculator, but i cannot figure out how to type and equal sign
Look at the top left corner of the keypad. If you have a = sign marked on the f ace of the calculator (near a CALc or Solve key) you can enter the = by pressing [ALPHA] then the key next to which there is an = sign.
If you do not have that second = sign, you cannot enter it.
The FX-115ES and the FX-991ES do have that sign to allow the user to enter equations. In your calculator you only have three calculational modes: the general COMP mode, the STAT mode and the Table Mode. No equation mode. Sorry.
This website keeps sending me in circles
  1. I checked your problems. There are three questions asked by you. The first one concerns how to insert the = sign to create an algebraic equation. It was answered correctly by someone.
[ALPHA][(-)] (A).
[ALPHA][' " "] (B).
[ALPHA][hyp] (C).
[ALPHA][sin] (D).
[ALPHA][ ) ] (X).
[ALPHA][S<=>D] (Y).
How do I put an = sign between eqasions? ie... 8x+7=5x-11
The calculator has two = signs,
  1. the = sign to execute a command, located at the right corner of keypad
  2. the = sign to insert in an equation.
This last one is accessed by pressing [ALPHA][CALC] (=). On the Casio FX-991 ES the [CALC] key is located on the top left corner of keypad.
1helpful
I have an equation: 6-2(5x-8) = 3x - 4. I need to
I will not ask what you want to do with the equation I will answer your question about the equal sign. Press [2nd][CATALOG] you access the catalog of available commands. The equal sign is near the bottom of the list. So it is faster to scroll up from the top, and keep scrolling up till you reach the =. Select it and press [ENTER], it will echoe at the place where the cursor was before you press [2nd][CATALOG]. Complete your equation.
Hope it helps.
1helpful
I can't see two graphics simultaneously.I write Y1= (something) and then i write another function Y2= (something). But when I click "enter" in the = sign of the second function, the black spot jumps to the...
To view both graphs, the = signs on both y1 and y2 must be contained in black boxes. If you put your cursor over the = sign on the second equation and hit enter, it turns that graph off and you won't be able to see anything but the equation in y1 line. If there is not black box around the = sign of any equation in any of the lines you have typed an equation into, you will not see the graph.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
